Posted: Fri Nov 04, 2011 11:41 am |
The wife bought a 2009 1.4 a few months ago and when checking the oil it is filthy so I thought I'd change it. Seems as though the last owner managed to totally mangle the last sump plug so I wanted to get a new one... but a different sort rather than the factory standard.
Does anyone know what the actual thread size of the plug is so I don't have to leave her car off the road whilst we wait for a new plug to arrive once i have sized it up myself?
Thanks in advance
Posted: Fri Nov 04, 2011 12:01 pm |
all it says on servicebox is "Oil drain plug 16x150"
Posted: Fri Nov 04, 2011 12:03 pm |
also, the OEM one is £1.15 from the main dealer
Posted: Fri Nov 04, 2011 12:05 pm |
They have slightly changed the design since the cars came out of the factory due to the 'old style' with the hex head rounding off too often.. The new style is a fully rounded edge one with a standard oil drain square socket piece hole in it..
Take the new plug to your local halfords or such and ask for the correct adaptor, they're fairly cheap IIRC
| The Cars:
Peugeot 206 1.6 HDi GTi '06 Plate - O/H's Car | |
Posted: Fri Nov 04, 2011 12:56 pm |
Even the older style there's nothing wrong with it if you use the correct socket to remove it.
Posted: Fri Nov 04, 2011 1:19 pm |
Thanks all. This one looks as though the last user must have just used the wrong socket to remove, and if they have had a history of rounding off, I guess I shouldn't be too surprised.
If they've changed the design, I might go and try the OEM one again. You can't go too wrong for that sort of price!
Posted: Fri Nov 04, 2011 1:39 pm |
Edward wrote: |
Even the older style there's nothing wrong with it if you use the correct socket to remove it. |
The tool for these Peugeot drain plugs isnt that expensive either.
Posted: Fri Nov 04, 2011 1:43 pm |
21/22mm socket always seems to do the trick on everyone I've done
Posted: Fri Nov 04, 2011 1:52 pm |
Lee wrote: |
21/22mm socket always seems to do the trick on everyone I've done |
i though the oem one was round bolt with a square slot?
Posted: Fri Nov 04, 2011 2:00 pm |
They've always been sockets with a square thing in the middle on the 7 different 206's i've done lol
Posted: Fri Nov 04, 2011 2:03 pm |
Lee wrote: |
They've always been sockets with a square thing in the middle on the 7 different 206's i've done lol |
i must have got the new bolts from dealer some how then as ste have said previously lol
Posted: Fri Nov 04, 2011 2:05 pm |
Mines a new one on the car, get a new one every service and that's just a normal hex bolt lol
Posted: Fri Nov 04, 2011 2:56 pm |
mines just a normal hex bolt too, dont my oil change yesterday
Posted: Fri Nov 04, 2011 3:10 pm |
I've had various ones all different, one even have an allen key hole in the middle..
Posted: Fri Nov 04, 2011 3:42 pm |
I have done shed loads of services in dealers and independant garages aswell as private and never had a issue with rounded sump plugs on and peugeot, in my opinion its all about the right size yes pug use differant options but all you have to do is look before you drain your oil, if you ar no master mechanic ask a garage or even use old faithfull molegrips just make sure you got a nice tight fit lol
