Posted: Mon Nov 07, 2011 4:02 pm |
pretty sure there is an aftermarket bonnet like that. Seen it a while ago,
Posted: Mon Nov 07, 2011 5:09 pm |
www.gumtree.com/p/cars...d/88654181
Mixed opinions but its something different. If you can do it go for it. Just locate the latch elsewhere grind the hook or whatever it is off that stops it coming up after you pull the latch.
Posted: Mon Nov 07, 2011 5:16 pm |
Yeah Bens looks really smart, seen it when people have the bonnet like that which also covers half the headlights, badboy style or something
Posted: Mon Nov 07, 2011 5:31 pm |
Not a fan, and to do it you would need to weld which would get tricky to shape right, or use a load of filler which is just going to fall off when you shut the bonnet
Posted: Mon Nov 07, 2011 5:40 pm |
Andrewxps wrote: |
Not a fan, and to do it you would need to weld which would get tricky to shape right, or use a load of filler which is just going to fall off when you shut the bonnet |
Could be fibreglassed.
Posted: Mon Nov 07, 2011 6:26 pm |
Trade Rating: +32
craigy00craig wrote: |
Looks like the s***ty bonnets you see on chav-tastic saxos. Not a fan |
Says the guy who's killed Jareds old car
Posted: Mon Nov 07, 2011 6:39 pm |
Matt wrote: |
Says the guy who's killed Jareds old car |
ooooo
Posted: Mon Nov 07, 2011 7:27 pm |
could work if done properly but obviously practical issues... air flow and cooling might be affected as well?
Posted: Tue Nov 08, 2011 10:31 am |
JordGJ wrote: |
could work if done properly but obviously practical issues... air flow and cooling might be affected as well? |
Wouldn't have though so the rad is bellow the top grill anyway.
Posted: Tue Nov 08, 2011 10:45 am |
Rob2859 wrote: |
JordGJ wrote: |
Wouldn't have though so the rad is bellow the top grill anyway. |
yeah I assumed that was just a thought
