Latest: heikkisj
Overall: 17126
Online Now [71]:
Visitors: 70
Today: 16589
Total: 100195219
Forums › The Car › 206 Problems › No power.
No power.
Go to page Previous  1, 2
PostPosted: Thu Nov 10, 2011 5:28 pm Up
colganraz wrote:
deebee wrote:
Im putting foot down and nuffin relli happens consid its a 2.0 turbo.
what you gotta remember is, ya may think its fast because its a '2.0 litre turbo' , but its a 90bhp diesel engine which is v. slow in my opinion.
my 1.2 corsa i had was probably about same 0-60 as 2.0hdi
maybe your just expecting a bit much??
edit -- you said it loses power after 3k revs too, i have found with diesels they lose power in higher rev range ( i think its because diesel wont burn fast enough or something lol)
You aren't driving it right then Wink
Mattie-RS
PostPosted: Thu Nov 10, 2011 5:30 pm Up
wrong! after 3k revs it should increase in power as thats where the turbo is at peak boost, it should then start to die off at about 5k revs
PostPosted: Thu Nov 10, 2011 6:39 pm Up
peak torque for stock 2.0HDi is @2000rpm, next to no power after 3500rpm.
peak boost 1bar @2K rpm; unless you are running K04 in which peak torque will shift up to around 3500rpm Laughing and massive amount of turbo lag Twisted Evil
colganraz
PostPosted: Fri Nov 11, 2011 5:33 am Up
i'm 90% certain after 3k revs it dies on power, i could be wrong though, i drove a 1.6 ds3 diesel an 1.9audi a3 diesel and they both lost power higher in the rev range
seabook seems to know what hes talking about though
Former 206 XSi owner - Now 207 GT
www.206info.co.uk/Foru...56475.html
deebee
PostPosted: Fri Nov 11, 2011 6:47 am Up
basically ive checked air intakes, had a mechanic check it aswell quickly, then ive tried the throttle cable, also im not expecting to much, when i brought the car it was awesome!!! but it feels like " its got a cold " lmao it just lags and the throttle pedal is pants!
Breaking 2.0 hdi with ps and gti bits
Big_Rich180
PostPosted: Fri Nov 11, 2011 7:03 am Up
Mattie its a derv you pleb, it will die off after 3k Laughing
PostPosted: Fri Nov 11, 2011 7:10 am Up
Max torque is at 2k
Max BHP is at 4k
Loudest is at 3k
MrrNoName
PostPosted: Fri Nov 11, 2011 7:42 am Up
Have you tried giving it a service, new filters, oil, etc?
If its way overdue a service that can make it seem like it has a "cold".
Diesels especially need nice fresh oil as they tend to contaminate it faster then petrol engines.
Aar_Im_A_Pirate
PostPosted: Fri Nov 11, 2011 7:44 am Up
fuel rail pressure?
Team: Derv
Dutch-HDi
PostPosted: Fri Nov 11, 2011 1:20 pm Up
Driving a derv is a diffrent experience totally than its pertol counterpart.
Fair enough you have a more limited rev range when driving hard id keep the revs between 2k and upto around 3.5k will keep the engine more happy than taking it to the red line at 5k Shocked Just dont rev em that hard FFS the power dies off b4 that anyways, torque is what a dervs about and if you think its down on power a good service as mentioned and a good remap will soon sort it out Thumb Up
1.2 corsa Laughing Laughing Laughing
206 HDi 2.0 XSi. Du7ch My Garage
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
- Albert Einstein (1879-1955)
deebee
PostPosted: Fri Nov 11, 2011 2:24 pm Up
well,
i personally recon its the maf sensor....
ramigojag
PostPosted: Fri Nov 11, 2011 2:26 pm Up
Tried air mass meter?
PostPosted: Fri Nov 11, 2011 3:05 pm Up
Get on the motorway at 70and drop it into 3rd gear. Watch all the s**t pour out the exhaust.
If that doesn't cure it, get the injectors checked and make sure you don't have a leak in the fuel lines which is sucking in air.
colganraz
PostPosted: Sat Nov 12, 2011 6:51 am Up
Whistle...
Page 2 of 2
