Online Now [313]:
Visitors: 312
Today: 5452
Total: 127827821
Forums › The Car › 206 Problems › 1998 1.1 206 rev issue
PostPosted: Fri Nov 11, 2011 4:29 am Up
Got more issues with this car, well they hadn't gone really.
I changed the ICV myself & reset the ECU and it was slightly better.
My friend took it to a garage (bit of a backsteet place from what I've heard) as it still had issues, I told her that it's most likely the MAP sensor so tell the garage that.
Now she doesn't know what they did/replaced as she knows nothing about cars, not sure if she even got an invoice Confused
The MAP sensor looks like it may have been replaced or cleaned.
Though she's still having the same trouble with the car.
Could it be anything else?
PostPosted: Fri Nov 11, 2011 4:32 am Up
Whats the problem with it?
PostPosted: Fri Nov 11, 2011 4:37 am Up
That would help Laughing
The revs either fluxuate or the car dies (sounds a lot like ICV to me but the one on there was brand new 500 miles ago)
PostPosted: Fri Nov 11, 2011 4:43 am Up
Coolant temp sensor working ok? TU sensors are a known failure point.
Cleaned the silicone grease of the ecu connectors? Another PSA c**k up Laughing
Throttle cable adjusted correctly?
Fuel & air filters ok?
Bosch spark plugs fitted?
Bouricord OR Electrofil coil pack?
Coil pack earth wire mod fitted?
PostPosted: Fri Nov 11, 2011 4:51 am Up
Cleaned the silicone grease of the ecu connectors? Another PSA c**k up Laughing - Not sure
Throttle cable adjusted correctly? Yes
Fuel & air filters ok? - New filters less than 500 miles ago.
Bosch spark plugs fitted? - Yes.
Bouricord OR Electrofil coil pack? - Unsure
Coil pack earth wire mod fitted? - What's this?
Ah good call there.
I noticed this morning that the fan was running when she shut the car off. The temp was at 90 degrees, so optimal.
PostPosted: Fri Nov 11, 2011 4:54 am Up
Coil pack wiring mod is Peugeot / Citroen part number 6555 K9 suppresor & its fitted beween pin 4 on the coil pack connector plug & earth.
Last time I checked price on that part it was less then £6.
I would check / clean the ecu connectors, wash all the silicone grease out if it hasnt been done already.
PostPosted: Fri Nov 11, 2011 5:07 am Up
So since the fan stayed on you think its most likely the coolant temp sensor?
PostPosted: Fri Nov 11, 2011 5:10 am Up
Could well be, ecu could think the engine is warmer then it should be & adjusts the fuel mixture the wrong way.
Whats it run like when the engine is warmed up?
PostPosted: Fri Nov 11, 2011 5:16 am Up
I've never driven the car so I don't know Laughing
From what I saw of it this morning the exhaust sounded quite bassy like when on auto-choke (you know what I mean) and the exhaust is standard.
PostPosted: Fri Nov 11, 2011 5:19 am Up
Is the exhaust system ok?
Any blowing can upset the ecu managment & running of the engine.
PostPosted: Fri Nov 11, 2011 5:22 am Up
I'll give the car a good look over this weekend.
Pretty sure the exhaust wasn't blowing though.
