Latest: heikkisj
Overall: 17126
Online Now [62]:
Visitors: 61
Today: 16301
Total: 100278631
Forums › The Car › 206 Talk › What connector?
What connector?
karimali831
PostPosted: Thu Nov 10, 2011 6:16 pm Up
I upgraded from frosted to crystal headlights, the setup is pretty much straight forward but the main lights uses different connector, so can anyone tell me I what connector I need as circled red in the picture:
And also the headlight bolts, current ones are too rusty. Smile
Thanks.
EDIT. Forgot to mention, do I need relay also with this also? If so can someone point my in the right direction where to buy the relay?
206 GTI 180
Ali_H
PostPosted: Thu Nov 10, 2011 6:18 pm Up
H4 to H7 adaptor.
kurtis wrote:
karimali831
PostPosted: Thu Nov 10, 2011 6:27 pm Up
Ali_H wrote:
H4 to H7 adaptor.
Where from? I'm looking for the straight 3-pin connector, looks the same as the adjuster motor lead.
206 GTI 180
PostPosted: Fri Nov 11, 2011 1:52 am Up
its not the same as the adjuster, its bigger.
PostPosted: Fri Nov 11, 2011 2:51 am Up
The adjuster motor plug is the exact sIze dj, just has the notch in different place so you can't fit it In Razz
Are you Any good at wireing karimali831 ?
PostPosted: Fri Nov 11, 2011 3:21 am Up
The connectors plugs & pins are less then £8 for a set from any Peugeot / Citroen main dealer.
This info has been covered / posted up no end of times on here by Lee & myself Rolling Eyes
PostPosted: Fri Nov 11, 2011 4:54 am Up
Nothing a stanley knife blade can't sort out Wink
PostPosted: Fri Nov 11, 2011 7:33 am Up
Exactly Laughing
Not that I have ever done that before Rolling Eyes Laughing
karimali831
PostPosted: Fri Nov 11, 2011 9:11 am Up
Yes I'm good at wiring, I just want a link to buy the parts because I won't be able to drive at night without them Smile
I was just about to go out to use the adjuster plug for the lights so you sure it won't fit in at all? And also the headlight bolts, can't find them anywhere. Sad
Thanks again.
206 GTI 180
karimali831
PostPosted: Fri Nov 11, 2011 7:11 pm Up
anyone know where to get 3-pin connector part please? Confused
"6541.J6" doesn't return any results for me..
206 GTI 180
PostPosted: Sat Nov 12, 2011 2:02 am Up
Have you been into the dealer and asked for that part number?
PostPosted: Sat Nov 12, 2011 4:27 am Up
Dont talk daft, thats far to easy Wink
karimali831
PostPosted: Sat Nov 12, 2011 6:31 pm Up
Waiting for monday Smile
I have another question, one end obviously to connect to the headlight but the other end the wires go into in from the loom? How does that work?
Cheers!
206 GTI 180
PostPosted: Sun Nov 13, 2011 2:53 am Up
This might be of big help, got a diagram that may be able to use to wire the plugs in.
www.206info.co.uk/Foru...18992.html
karimali831
PostPosted: Mon Nov 14, 2011 8:05 pm Up
I have got the clips now and understand the wiring diagram but don't understand how the wires will fit inside? I was told there is another part that connects to the clip but is not sold as a seperate as it should come from the loom. For my case I just have those 3 wires and clip any suggestions?
206 GTI 180
