Online Now [65]:
Visitors: 64
Today: 44259
Total: 117157682
Forums › The Car › Solved 206 Problems › Hesitant to Start when cold BUT.. [-SOLVED-]
Go to page Previous  1, 2, 3
PostPosted: Sun Nov 06, 2011 7:22 am Up
Another update:
Pump is whiring in second click key position.
Earths appear intact.
Have now again taken the airfilter hose off and trying to watch the butterfly behaviour.
Appears to be completely shut at start-up, even though the throttle actuator is whiring and holds lock to the butterfly.
When idling, it still looks prety closed to me, until pressing the accelerator pedal where it seems to opperate fine.
Engine runs fine, plenty of power etc. appart from slight jolt of power sometimes when pressing the pedal.
Eh?
PostPosted: Sun Nov 06, 2011 8:25 am Up
Checked the throttle position sensor?
PostPosted: Sun Nov 06, 2011 9:29 am Up
I think that is inside the actuator unit, not like an external pot as usual.
What do you suggest to check?
PostPosted: Sun Nov 06, 2011 9:35 am Up
Tell me your VIN number and I'll check to see if there are anythings flagged up on servicebox
PostPosted: Sun Nov 06, 2011 10:06 am Up
Check your email Smile
PostPosted: Sun Nov 06, 2011 10:27 am Up
Cheers matey.
I'll have to go through all that. Wink
PostPosted: Fri Nov 11, 2011 11:01 am Up
- SOLVED -
ECU update to the latest version needed due to bad software version from a previous update on 14/9/2007.
For reference this is before:
(note sometimes it would not fire-up at all when completely cold and needed 2-3 goes).
s875.photobucket.com/a...V01452.mp4
After the update of ECU (flash programing):
s875.photobucket.com/a...V01466.mp4
This is now confirmed and the overall performance of the engine is much improved.
The 'jolts' when pressing accelerator if cold are completely gone. Smoother throughout the rev range.
No loss of power compared to before.
Much quieter engine (thought it had stalled on idle a couple of times).
Ever so slightly lower engine temp.
Thank you Lee for coming up with this:
The chap on PP2000 at Peugeot dealership also gave me this:
Which I translated btw.
Cost 50 EUR all in.
Mine is up next I think.
Cheers everyone. Very Happy
Daeva
PostPosted: Fri Nov 11, 2011 11:29 am Up
It's been great help to hear from all of you!
The car runs smoothly and starts every time.
All your input is appreciated! Smile
1.4i, 2007, TU3A, 5-door, Moonstone
PostPosted: Fri Nov 11, 2011 12:29 pm Up
Cool
Page 3 of 3
