Posted: Thu Nov 10, 2011 12:25 pm |
Posted: Thu Nov 10, 2011 12:42 pm |
Bolts to the crossmember
Posted: Thu Nov 10, 2011 12:45 pm |
that makes sense. didnt think of looking at that.
thanks lee
Posted: Thu Nov 10, 2011 12:50 pm |
Near the bottom hose on the radiator I think
Posted: Thu Nov 10, 2011 1:09 pm |
Is it the earth for the cooling fan? Is this on the right hand side of the engine bay?
i.e. this?
Posted: Thu Nov 10, 2011 1:14 pm |
its to the left side as you look at the engine, comes up from the same loom that has the alternator cable in etc.
Posted: Thu Nov 10, 2011 3:31 pm |
I'm gonna call it Dave.
Posted: Fri Nov 11, 2011 11:37 am |
been out and had a quick look and it dont seem long enough to reach without stretching ?
suppose we will find out when i try start it weekend
Posted: Fri Nov 11, 2011 11:39 am |
If the numbers on the wire start with MC then it's a earth, if it doesn't then it's something else.
Posted: Fri Nov 11, 2011 11:41 am |
is that same rule for all the earth cables on these cars?
Posted: Fri Nov 11, 2011 11:42 am |
All Peugeot and Citroen
Posted: Fri Nov 11, 2011 11:44 am |
nice one
going to fill it up with fluids/oil and try start it tomorrow so we will find out if it improtant
Posted: Fri Nov 11, 2011 11:45 am |
Well it should be with it being like that.
MC = Earth to body work
MM = Earth to battery
ME = Earth linked to ECU
Posted: Mon Nov 14, 2011 9:11 am |
just to let you know its something to do with alternator i think, as my alternator is faulty (found out today) when it connected to earth the batt light on dash shows when car is running but dont show when its not connected earth.
Posted: Mon Nov 14, 2011 9:47 am |
| Dabamash wrote: |
| I'm gonna call it Dave. |
Most helpful post of the year
That reminds me to take a photo, In front of my sump I have some wires that don't go anywhere. Looks like they have been chopped
