Posted: Thu Nov 10, 2011 7:16 pm |
Posted: Thu Nov 10, 2011 7:18 pm |
H4 to H7 adaptor.
Posted: Thu Nov 10, 2011 7:27 pm |
Ali_H wrote: |
H4 to H7 adaptor. |
Where from? I'm looking for the straight 3-pin connector, looks the same as the adjuster motor lead.
Posted: Fri Nov 11, 2011 2:52 am |
its not the same as the adjuster, its bigger.
Posted: Fri Nov 11, 2011 3:51 am |
The adjuster motor plug is the exact sIze dj, just has the notch in different place so you can't fit it In
Are you Any good at wireing karimali831 ?
Posted: Fri Nov 11, 2011 4:21 am |
The connectors plugs & pins are less then £8 for a set from any Peugeot / Citroen main dealer.
This info has been covered / posted up no end of times on here by Lee & myself
Posted: Fri Nov 11, 2011 5:54 am |
NorthantsBen wrote: |
Are you Any good at wireing karimali831 ? |
Nothing a stanley knife blade can't sort out
Posted: Fri Nov 11, 2011 8:33 am |
Lee wrote: |
Nothing a stanley knife blade can't sort out |
Exactly
Not that I have ever done that before
Posted: Fri Nov 11, 2011 10:11 am |
Yes I'm good at wiring, I just want a link to buy the parts because I won't be able to drive at night without them
I was just about to go out to use the adjuster plug for the lights so you sure it won't fit in at all? And also the headlight bolts, can't find them anywhere.
Thanks again.
Posted: Fri Nov 11, 2011 8:11 pm |
anyone know where to get 3-pin connector part please?
"6541.J6" doesn't return any results for me..
Posted: Sat Nov 12, 2011 3:02 am |
karimali831 wrote: |
"6541.J6" doesn't return any results for me.. |
Have you been into the dealer and asked for that part number?
Posted: Sat Nov 12, 2011 5:27 am |
macca1411 wrote: |
Have you been into the dealer and asked for that part number? |
Dont talk daft, thats far to easy
Posted: Sat Nov 12, 2011 7:31 pm |
MrBSI wrote: |
macca1411 wrote: |
Dont talk daft, thats far to easy |
Waiting for monday
I have another question, one end obviously to connect to the headlight but the other end the wires go into in from the loom? How does that work?
Cheers!
Posted: Sun Nov 13, 2011 3:53 am |
Posted: Mon Nov 14, 2011 9:05 pm |
I have got the clips now and understand the wiring diagram but don't understand how the wires will fit inside? I was told there is another part that connects to the clip but is not sold as a seperate as it should come from the loom. For my case I just have those 3 wires and clip any suggestions?
