Online Now [439]:
Visitors: 438
Today: 144330
Total: 156859084
Forums › The Car › Request a how-to › Need a how to for Remove-Refit of the timing belt.
TheGTIlad
PostPosted: Sun Nov 13, 2011 6:52 am Reply with quote Up
Basically as the title says really. Going to buy a timing belt kit as i have an annoying squeel from the timing side of my engine on a 2.0 gti 136.
Any help would be greatly appreciated.
PostPosted: Sun Nov 13, 2011 7:00 am Reply with quote Up
You won't get one. It's quite a big job. ECU needs removing, engine needs shifting off the mounts otherwise the covers won't come off...
A Haynes manual is useful but it does the job in a 307 which isn't as difficult.
PostPosted: Sun Nov 13, 2011 8:57 am Reply with quote Up
Squeal? sure its not the aux belt?
gazza82
PostPosted: Sun Nov 13, 2011 9:57 am Reply with quote Up
kieron posted one on here for a 2.0i which I used for our CC without any problems.
http://www.206info.co.uk/Forums/viewtopic/t=30420.html
I used bolts rather than trying to find the cam lock/pins .. which is exactly how a local Pug specialist recommended I did it ...
TheGTIlad
PostPosted: Sun Nov 13, 2011 12:22 pm Reply with quote Up
No im not sure which belt it is, but I cannot find a receipt for a timing belt either so im unsure if its been done or not so might as well change it.
TheGTIlad
PostPosted: Sun Nov 13, 2011 12:58 pm Reply with quote Up
Thank you very much mate! Much appreciated!
gazza82
PostPosted: Sun Nov 13, 2011 12:59 pm Reply with quote Up
What's the mileage on said 138 and how old is the car? Timing belts have a working life of miles or years, whichever comes first.
TheGTIlad
PostPosted: Sun Nov 13, 2011 1:09 pm Reply with quote Up
its 97k, and its a 2001 X plate car originally, changed to a private plate.
PostPosted: Sun Nov 13, 2011 1:19 pm Reply with quote Up
60k or 5 years, which ever is first
TheGTIlad
PostPosted: Sun Nov 13, 2011 1:21 pm Reply with quote Up
If mine is 97k, and the period is 60k or 5 years, is it possible mines had one already or can some last this long on one cambelt?
PostPosted: Sun Nov 13, 2011 1:27 pm Reply with quote Up
Its possible it might still be on the original timing belt.
TheGTIlad
PostPosted: Sun Nov 13, 2011 1:32 pm Reply with quote Up
She-ite. I know what I'm going to price up asap then.
  Quick Reply
Username:
Message:
Quote the last message
