Posted: Sun Nov 13, 2011 1:46 pm |
Does anybody know where the fuel pump relay is on an 2002 1.4 hdi?
or sugestion why the fuel pump wont run, Pumpmis fine and fuse is fine.cheers
| haggis120 206 1.4 Hdi, 2002 | |
Posted: Sun Nov 13, 2011 1:51 pm |
It's under the ECU
I have two spare if you need one
Posted: Sun Nov 13, 2011 1:53 pm |
Lee is the ECU in the engine bay as I have liffted this and there is nothing there?
Posted: Sun Nov 13, 2011 1:55 pm |
Yes.
It should be, a brown relay, about 15 pins
Posted: Sun Nov 13, 2011 1:57 pm |
at the drivers side behind headlight unit? nothing there.
Posted: Sun Nov 13, 2011 2:50 pm |
Under the ECU, if you put your ear near, and get someone to turn the ignition on, you will hear the Relay.
