Posted: Mon Nov 14, 2011 12:28 pm |
What tools are needed?
Other things to replace along the way "while you are there" soty of things.
Do 206's have stretch bolts?
Posted: Mon Nov 14, 2011 12:30 pm |
p**sing in to the wind until you tell us what engine you have
Posted: Mon Nov 14, 2011 1:44 pm |
I think its a traction engine
Posted: Mon Nov 14, 2011 3:11 pm |
| macj wrote: |
| I think its a traction engine |
My first thought too
Posted: Mon Nov 14, 2011 3:30 pm |
I reckon it's for a paddle steamer.
Posted: Mon Nov 14, 2011 3:31 pm |
sorry
1.4 8v petrol
Posted: Wed Nov 16, 2011 7:57 am |
dont even attempt it unless you know what your doing, ive rebuilt a few heads and theyre easy to screw up as is engine timing if you dont do it right
| need any parts give me a shout  | |
Posted: Wed Nov 16, 2011 8:15 am |
I know our HDi can be a bit smokey on hard acceleration, but I don't know that I've ever had to load up the boot with coal and fill the water tanks!
Do you think the OP means "valve STEM seals" ... ????
