Latest: tc.206
Overall: 17147
Online Now [165]:
Visitors: 164
Today: 2860
Total: 116499490
Forums › The Car › 206 Talk › what does my car have?
Go to page Previous  1, 2, 3
Ape
PostPosted: Tue Nov 15, 2011 10:18 am Up
Nope Wink
Just cut the relevant bit out of the previous post instead of copying the whole quote Wink
PostPosted: Tue Nov 15, 2011 11:33 am Up
MrBSI wrote:
Ape wrote:
MrBSI wrote:
Ape: EBD only works on the rear axle, its just an electronic version of the old rear brake compensator load valve Wink that unit that always rusts up & fails the mot on older 206's Laughing
I know bud, hence (see bold bit)...
Ape wrote:
Electronic Brake Force Distribution-
Can brake individual wheels to correct / stabilise the car depending on loadings (effectively an electronic brake bias valve controlled by the ABS unit)
Nice post edit Wink
I noticed that Laughing , was going to say it wasn't the same as ESP then it was changed.
PostPosted: Tue Nov 15, 2011 11:40 am Up
www.youtube.com/watch?v=ZD8krFh8IL4
Won't load up in the flash player for some reason
PostPosted: Tue Nov 15, 2011 11:42 am Up
Not working Lee.
dumdum0910
PostPosted: Tue Nov 15, 2011 12:14 pm Up
my car does have abs. what is the link for service box?
PostPosted: Tue Nov 15, 2011 12:18 pm Up
public.servicebox.peug...ors_eu.jsp
You need to register for a FREE account or find some log in details from somewhere else / ask someone else nicely to look the VIN up.
PostPosted: Tue Nov 15, 2011 12:22 pm Up
V9977 wrote:
Not working Lee.
Flash player won't work on here for some reason Confused
Did it right...
Code::
[flash width=380 height=380]http://www.youtube.com/watch/v/ZD8krFh8IL4.swf[/flash]
PostPosted: Tue Nov 15, 2011 12:31 pm Up
Lee wrote:
http://www.youtube.com/watch?v=ZD8krFh8IL4
Hmm..
I must say that is pretty impressive that esp system.
I din't imagine it was such a high-tech thing 206's came with.
Retrofit!
PostPosted: Tue Nov 15, 2011 12:37 pm Up
Hmm..
Retrofit!
Needs cabin wiring loom as the yaw sensor lives under carpet below left hand seat, replace the ABS unit with the ESP version, ESP version of master cylinder, com 2000 with ESP steering angle sensor, esp off switch for dash, BSI configuration update for a start.
Dutch-HDi
PostPosted: Tue Nov 15, 2011 12:38 pm Up
Great link, Thanks Lee Thumb Up
206 HDi 2.0 XSi. Du7ch My Garage
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
- Albert Einstein (1879-1955)
PostPosted: Tue Nov 15, 2011 12:40 pm Up
MrBSI wrote:
Hmm..
Retrofit!
No, I was kidding as I imagined it would be cheaper to get a car with it as standard.
PostPosted: Tue Nov 15, 2011 12:42 pm Up
Any new car you purchase now should have ESP fitted as standard thanks to the EU law makers.
Only a few new cars can get away with not fitting it due to low volume production & other get out clauses.
PostPosted: Tue Nov 15, 2011 6:03 pm Up
You'll still be able to buy new cars without ESP, for now, it's only new models that'll need ESP as standard to gain 'type approval'. ESP will become compulsory in all new cars from October 31, 2014.
crocdino
PostPosted: Sun Nov 20, 2011 7:23 am Up
Our 138 has ESP and that. It's a later facelift car, though.
GTI 138 facelift - Runabout
335d M Sport - Cruiser
Page 3 of 3
