Latest: Andyblue64
Overall: 17123
Online Now [415]:
Visitors: 413
Members: 1
Today: 85653
Total: 98596971
Forums › The Car › 206 Problems › Air bag light
Air bag light
PostPosted: Tue Nov 15, 2011 5:29 pm Up
on a preplexed 206;
light was flashing due to the pretensioner was unplugged.
by any chances i can turn that off in PP2000?
i can't seems to find that option in the menu though.... Confused
PostPosted: Tue Nov 15, 2011 5:47 pm Up
Airbag light should go out by itself when the system is working correctly.
Are you sure everything is connected correctly?
Not fired a pretensioner has it?
If you have PP2000 then you should be able to scan the airbag system for faults & see what it reports.
PostPosted: Tue Nov 15, 2011 5:58 pm Up
yes, the light was flashing because the pretensioner was unplugged..
PostPosted: Tue Nov 15, 2011 6:01 pm Up
If everythings connected & ok then the airbag light should go out after its pre start self test.
You got PP2000 to scan it with?
PostPosted: Tue Nov 15, 2011 6:23 pm Up
i think i should make it clear as i want the light off even when the pretensioner remain unplugged Laughing
PostPosted: Wed Nov 16, 2011 11:26 am Up
Why do you want the pretenioner unplugged?
Correct operation of airbag warning light coming very soon to the mot test Wink
PostPosted: Wed Nov 16, 2011 12:44 pm Up
because i don't have oem seatbelt in the car..... Confused
PostPosted: Wed Nov 16, 2011 12:45 pm Up
Plug the pretensioner back in, measure the resistance then fit a resistor.
Or reconfig the ECU
PostPosted: Wed Nov 16, 2011 12:49 pm Up
you can't turn it off with any of the airbag system is not complete,unless you wanna do as Lee said,but i wonder why u want the pretensioner unpluged ??
PostPosted: Wed Nov 16, 2011 12:50 pm Up
Or reconfig the ECU
what do you mean by reconfig the ECU?
i don't seems to recall i can disable the airbag via PP2000 Crying or Very sad
PostPosted: Wed Nov 16, 2011 12:59 pm Up
Go into the Airbag ECU and go to configuration, I think you can change the settings.
If not, go into the BSI and de-activate the ECU
PostPosted: Wed Nov 16, 2011 1:03 pm Up
Ok, will check again tmr to see if i got that options Laughing
Cool
PostPosted: Wed Nov 16, 2011 1:33 pm Up
I would be tempted to leave the standard seatbelts fitted & connected even if there not used just for the time being Wink
PostPosted: Wed Nov 16, 2011 6:36 pm Up
it can only be 1/3 fit properly as it crashed with the rollcage near the b-pillar
