Posted: Wed Nov 16, 2011 4:44 am |
| greenpug2222 wrote: |
I have this too,
It seems to only make the water noise upon acceleration. Even in neutral for a good while, whilst it warms up.......... then after it seems to get less and less. | #
Yup i get that to, Press the throttle and there's like a rush of water coming from around the glovebox area, dont have a clue what it is. I have looked and it doesnt seem to be a Cause of any problems but as i said i really dont know, I do hope it isnt the head gasket. My last car's gasket went absolute nightmare, Rover 400 1.4 though, seems to be expected
Posted: Fri Nov 18, 2011 3:17 am |
if this is the head gasket then why does it not do it all the time???? and not just when im driving a cold car.
| why wont you work??????????????????? ARGH F**k it!!!!! | |
Posted: Fri Nov 18, 2011 5:29 am |
It's just ure coolant system running through the heater matrix. You may have a bit of air lock in the system causing the trickling noise that's all!
Posted: Fri Nov 18, 2011 5:32 am |
Ok I posted without reading the first post, so ignore the above comment lol!
Posted: Fri Nov 18, 2011 5:36 am |
had the same noise with both 306 gti6's i owned shouldnt be anything to worry about.
Posted: Fri Nov 18, 2011 6:42 am |
| if this is the head gasket then why does it not do it all the time???? and not just when im driving a cold car. |
because metal expands and creates a tighter seal on the gasket? thus reducing/eliminating any air leak
Posted: Tue Nov 22, 2011 3:15 pm |
ok ive looked into this a bit more and it only seems to do it in 1st-3rd gear. Im not saying its related but this is what ive witnessed.
my car does not over head and the temp needle sits between 80-90 ish all the time....
Does everyone still think its the head gasket????
Posted: Wed Nov 23, 2011 2:39 am |
Take it to a garage and ask them to check for exhaust gasses in the coolant. thay will tell you if the head gasket has gone/is going.
Posted: Fri Nov 25, 2011 11:51 am |
this started happening on my car and i checked the coolent level and it was really low (took nearly 2 ltrs of water to get back to normal level) and now its fine, always check the easy/ less expensive stuff first lol
Posted: Fri Nov 25, 2011 11:55 am |
water / heater pipes that come in and out cabin are down glovebox side,
check its bled and not low on water. or even leaking.
Posted: Wed Dec 21, 2011 7:02 pm |
My car is still doing this,
Ive found that somehow water is being spray/leaked out of the expansion tank but i can not find out where. The lid is on tight,there are no cracks or holes in it and i still get the noise.............
Posted: Thu Dec 22, 2011 4:34 am |
Ive found that somehow water is being spray/leaked out of the expansion tank but i can not find out where. The lid is on tight,there are no cracks or holes in it and i still get the noise............. |
Change the pressure cap then, if the spring inside is weak it will allow the coolant to escape out.
There only £3.67 new from any Peugeot / Citroen main dealer.
