Latest: flipflap
Overall: 17140
Online Now [101]:
Visitors: 100
Today: 9557
Total: 113757263
Forums › The Car › 206 Problems › wont tick over
wont tick over
PostPosted: Sat Nov 19, 2011 2:35 pm Up
dumdum0910 wrote:
managed to get all the links open and had a look through cant really see anything in there. and im sure my 1.1 doesnt have a egr? if thats the remote cansister? i will go have a look now on live date at the temp sensor
It does.
PostPosted: Sat Nov 19, 2011 2:38 pm Up
V9977 wrote:
MrBSI wrote:
dumdum0910 - that video takes me back to 2005 when my 206 used to idle poorly then cut out at random, ahhh the memories Laughing
And the solution was...
Throw it back at a Peugeot main dealer until they fixed it under manufacturers warranty.
Could have been 1 or more of the 24 visits it had back to the dealer for various warranty work in the last year of the manufacturers warranty period that fixed it.
PostPosted: Sat Nov 19, 2011 2:40 pm Up
Ah, OK.
PostPosted: Sat Nov 19, 2011 2:43 pm Up
Lost count of the amount of engine ecu & BSI software updates it had under warranty Laughing
Not had a software update since Dec 07, might have to get an update in the new year Laughing
PostPosted: Sat Nov 19, 2011 2:49 pm Up
I'm taking mine in next week.
Last update on ECU was in 2004. Wink
dumdum0910
checked the live data the coolant temp seems to be ok.. i noticed the timing seems to be up and down. went down to 7% and as high as 16% not sure if this was to do with the idle being up and down
PostPosted: Sat Nov 19, 2011 2:53 pm Up
I think that might be normal as it depends on the rpm at any given moment.
I would check the EGR cannister valve as in the info flash as it gives instructions without replacing anything, just to make sure.
dumdum0910
PostPosted: Sat Nov 19, 2011 2:56 pm Up
were is the egr on the 1.1 tu1jp ? dont wanna sound dumb.
PostPosted: Sat Nov 19, 2011 2:58 pm Up
I think it would be on the rear-left hand side looking at the engine bay tucked away somewhere.
Someone else might have a better idea.
Looks like a coke can with hoses going into it.
Might be under the wheel arch too.
dumdum0910
PostPosted: Sat Nov 19, 2011 3:04 pm Up
ok i will have a look tomorrow, i dont really understand what it says on the link , which pipe do you remove? the 1 from the engine that goes in to the valve or another 1 and how to you plug the tapping in the valve to check its working?
PostPosted: Sat Nov 19, 2011 3:13 pm Up
As your symptoms are quite severe, I would just see if it makes any difference using finger as suggested in the first instructions. Shocked
I don't know which of the two pipes but I would imagine the one that has the valve on it.
This is all just to make sure, not a definate fix obviously.
Keep at it though.
dumdum0910
PostPosted: Sat Nov 19, 2011 3:16 pm Up
just had a quick look. found the valve beind the coolant bottle toke the pipe off the valve , put my finger on it had some good sucktion , removed my finger and seems to run normal at 1000 rpm , replaced the pipe back on the valve and it runs crap again, think ill b visiting peugeot on monday to get a replacment
PostPosted: Sat Nov 19, 2011 3:18 pm Up
Very Happy
Hope you get it sorted mate and let us know for future ref.
dumdum0910
PostPosted: Sat Nov 19, 2011 3:19 pm Up
will do mate, i will get to peugeot monday morning and get it ordered in
PostPosted: Sat Nov 19, 2011 3:26 pm Up
Wait, 1000 rpm is still high. Is your engine cold?
It says in the instructions "during the first minute" etc.
Have a good look at the bahaviour before you order any parts to make sure.
Normal idle should be at 750 rpm line when engine is warmed up.
Page 5 of 8
