Online Now [488]:
Visitors: 487
Today: 53986
Total: 128154740
Forums › The Car › Solved 206 Problems › IMMO Problem Peugeot 206 1.4 2006
millanz
PostPosted: Sat Nov 19, 2011 4:06 am Up
hi friend
Need your assistance please... Smile
Peugeot 206, 1.4 KFW, TU3JP year 2006.
VIN VF32AKFWR439XXXXX.
RPO 10377
ECU S2000-PL4FC5 (EEprom 95160) 9655659480 . PSA 9656972780
Part Number 21585264-8A
Almost one week my car can not start because immobiliser is function.
Scanning On PP2000 :
Problem detected when transmitting unlock code, Engine immobiliser code can not be read,
ECU status Locked.
all ECU's tested and running well within the "global test" and found no errors.
In the "Engine ECU" is mentioned - PP2000 unknown reference, Ecu being referenced (this may be due to the ECU was locked so that communication does not exist)
All system wiring and connectors in good condition.
I can communicate with the Engine ECU via Test by ECU (KFW S2000) I can read all parameters, but the ECU will remain locked
Trying to make learning the transponder, and succeeded. Ican change status of the BSI from locked in to unlocked, the transponder can be recognized but the ECU is still locked: ((
In my opinion. Eprom in the ECU 96160 S-2000-PL4FC5 that store immo code was corupted. So the ECU immo code can not be read by the BSI.
The problem that I would ask is:
Maybe anyone has any fresh dump for my Engine ECU?
In the Engine ECU, Memory EPROM used is 95 160. What software can I use to check or examine its EPROM dump. because I see a lot of outstanding software can only read eeprom 95080 in S2000.
Or reading "95160" is equal to the reading of "95080"? Example of the software immo killer
Can I do a re-coding for my ECU or maybe Immo off for it (S2000-PL4FC5)?
Before and after that I say many thanks to you all
Sincerely Regards ....
I attach some screenshots of PP2000
PostPosted: Sat Nov 19, 2011 5:04 am Up
1) No need to post your VIN
2) Aerial on ignition barell definately OK?
3) You can always re-flash the ECU with the latest software but not sure
how much it would help in this case.
PostPosted: Sat Nov 19, 2011 5:43 am Up
I think I have a virgin dump, will check.
Don't forget to correct checksum when using universal software
millanz
PostPosted: Sat Nov 19, 2011 7:40 pm Up
Thank mate..
1. Ok friends ... I will edit my post ....
2. Yes ... all works very well ... transporder well recognized ... can be seen in the attachment below.
3. When i try to download the software for the ECU. PP2000 mentioned that there is a new version for solving the problem of "knocking problem".
206 forever.....
millanz
PostPosted: Sat Nov 19, 2011 7:59 pm Up
Thank you master ...
My friend, you are truly my savior.
I use Willem Prog / PonyProg to open the dump file in the EPROM 95160. About your virgin dump, It still requires re-coding or already in the unlock? I hope I get way out of this problem.
Actually my car has been put into the nearest Peugeot dealer., But after working for almost a week they can not provide a clear conclusion .. huffffffffff ... They were asked to replace ecu but they do not want to guarantee that it will solve the problem ...... Evil or Very Mad , so finally, I pull my car back to my garage.
regards
206 forever.....
PostPosted: Sun Nov 20, 2011 6:09 am Up
Were they not able to update/re-program the ECU with PP2000 at the dealer's?
PostPosted: Sun Nov 20, 2011 6:20 am Up
Post thedump and I'll remove or virginse the data
PostPosted: Sun Nov 20, 2011 6:55 am Up
Cool.
millanz
PostPosted: Mon Nov 21, 2011 11:48 am Up
Yes. we certainly can update the software at authorized dealers, but i believe they certainly do not want to re-code immo via dump techniques.
If we buy a Brand New ECU, only authorized repair shop who can do the reprogramming software from scratch (or maybe someone got access to PSA Smile ). It because they have our car history, configuration data and other related matters.
The new ECU has only one chance for coding pin and when an error occurs it will be a big problem (dump techniques maybe the solution). Corect me if i am wrong ... friend
206 forever.....
millanz
PostPosted: Mon Nov 21, 2011 11:53 am Up
Thanks you so much. I'll try to take the dump file tomorrow .. My Hot Air Gun possible in less than optimal conditions are now Sad . Preparing to look for another one tomorrow afternoon ...
regards
206 forever.....
millanz
PostPosted: Sat Nov 26, 2011 3:27 am Up
hi friend
I need your help and assistance. thank you for your kindness
here is ecu dump for my car ...
Please check it out......
My Immo Code RJ4N
Dump S2000PL4FC5-Eprom 95160
206 forever.....
PostPosted: Sat Nov 26, 2011 5:32 am Up
Hi,
You don't have a PIN programmed into that dump
Yours.....
Pin Programmed in.......
Immo off.......
See the difference?
I can upload the files, but not sure if they will work as I think the original dump might be corrupt
PostPosted: Sat Nov 26, 2011 5:47 am Up
You cant beat a good dump in the morning Rolling On The Floor Laughing
millanz
PostPosted: Sat Nov 26, 2011 8:12 am Up
Lee wrote:
Hi,
Yes, I understand the difference. It's likely the file has been corrupted. I hope you can upload that file, so I can try to do the writing process to the chip. I will report the results as soon as possible to you friend ....
What if I have the raw files from the Peugeot 206 S2000-PL4FC5 ECU? whether it will become easier or the same result?
thank you very much.
206 forever.....
PostPosted: Sat Nov 26, 2011 8:20 am Up
Here are the two files.
The one with the pin programmed in, and the one with the immo off.
I'll PM you the password
