Latest: slaapkonijn
Overall: 17169
Online Now [190]:
Visitors: 189
Today: 31230
Total: 128696908
Forums › The Car › 206 Problems › Knocking from rear
Knocking from rear
JonnyGTI
PostPosted: Tue Nov 22, 2011 10:04 am Up
Been told this could be my rear axle causing this. Would replacing the bushes resolve this and if I can replace them would do they need to be pressed in and pressed out?
Cheers jonny
ExoVyper
PostPosted: Tue Nov 22, 2011 11:55 am Up
yeah its the axle and it's easyier and sometimes a bit cheaper to just buy another axle rather than faff with bushes
kakaruto
PostPosted: Tue Nov 22, 2011 11:58 am Up
Lee is selling a rear disc axle pm him Very Happy £180! with brand new handbrake cables too!
i wish i bought this :L
2001 Y 206 1.4 LX Black
PostPosted: Tue Nov 22, 2011 12:17 pm Up
Normally by the time you notice the bearings want replacing on the rear axle its beyond repair as the stubs get damaged / marked by the defective bearings.
Fitting new bearings to a damaged axle is a waste of time as they wont last very long.
By all means strip it apart but be ready to get another rear beam.
JonnyGTI
PostPosted: Tue Nov 22, 2011 12:51 pm Up
been checking prices off the rear beams out today also the cheapest i can find is £235 with the dearest being £700
Cheers jonny
JonnyGTI
PostPosted: Tue Nov 22, 2011 1:11 pm Up
could u point me in the right place for this post as i cant seem to find anything
Cheers jonny
PostPosted: Tue Nov 22, 2011 1:14 pm Up
just pm him......
JonnyGTI
PostPosted: Tue Nov 22, 2011 1:19 pm Up
whats his name on here as there is a few lee's that i have seen in the short time i have been here
Cheers jonny
ExoVyper
PostPosted: Tue Nov 22, 2011 1:33 pm Up
it's literally just 'Lee'
PostPosted: Tue Nov 22, 2011 1:49 pm Up
this Lee
www.206info.co.uk/Your...e=Lee.html
JonnyGTI
PostPosted: Wed Nov 23, 2011 12:28 pm Up
Would any axle be ok on the gti as long as its discs and abs
Even if it's off a cc or lower engine'd car as long as I change the shocks over
Cheers jonny
PostPosted: Wed Nov 23, 2011 12:31 pm Up
Just needs to have the same electrical system as yours
Gaz-M
PostPosted: Thu Nov 24, 2011 5:45 pm Up
Even buy a drum one and swap the brakes/stubs over.. Thats not the easiest job in the world though. But possible!
Diesel Power!!
JonnyGTI
PostPosted: Sun Nov 27, 2011 10:54 am Up
Got hold off a rear axle off a 2000 plate gti that's just come in
Now probably a silly thing to ask but should I just change the bearings on the new/2nd hand axle while it's off the car
Cheers jonny
Gaz-M
PostPosted: Sun Nov 27, 2011 2:53 pm Up
If theyre fine i'd leave it..
Diesel Power!!
