Latest: DanDan17
Overall: 17128
Online Now [60]:
Visitors: 59
Today: 17985
Total: 100578667
Forums › The Car › 206 Problems › strange sound from the rear of my gti :/
xxkazxx
PostPosted: Tue Nov 22, 2011 11:53 am Up
started a few days ago it sounds like the exhaust but that is solid i know i have drop links gone on the front but would that make the same sound?
panzer360gti
PostPosted: Tue Nov 22, 2011 1:54 pm Up
sound travels down the car through heat shield/bodywork etc, could be the sound from the links resonating.
or rear suspension, or summat in your boot you forgot about (done that!)
Peugeot 206 GTI 137 2.0
Linkpad
PostPosted: Wed Nov 23, 2011 4:11 am Up
Maybe wheel bearings. quite common on an old 206 ?
Boo
PostPosted: Wed Nov 23, 2011 6:41 am Up
Well if there is a problem at the front which you know about you need to get it fixed. Cost less than £30 for the parts.
xxkazxx
PostPosted: Wed Nov 23, 2011 7:40 am Up
bits come back today £12.50 off ebay Wink ...
i wouldnt call it old 53 isnt that old Wink
