Latest: DanDan17
Overall: 17128
Online Now [184]:
Visitors: 183
Today: 22829
Total: 100420996
Forums › The Car › 206 Problems › fuel level
fuel level
haggis120
PostPosted: Wed Nov 23, 2011 6:40 am Up
I replaced my fuel level sender yesterday as there was a crack on the top of the unit. The gauge seemed to come on at the same level that the old one was at so I thought it was fine. The tank level was bellow quarter when I changed it so I put in £40 of diesel last night but the gauge did not rise it just keeps going down. Any ideas? I have tried BSI reeboot but no joy. Cheers
haggis120 206 1.4 Hdi, 2002
PostPosted: Wed Nov 23, 2011 8:07 am Up
Was the new one actually new or second hand?
haggis120
PostPosted: Wed Nov 23, 2011 8:08 am Up
It was brand new.
haggis120
PostPosted: Wed Nov 23, 2011 8:09 am Up
I have tested the sender and it is fine correct ohms for the different positions.
PostPosted: Wed Nov 23, 2011 8:15 am Up
Did the needle work before?
haggis120
PostPosted: Wed Nov 23, 2011 8:16 am Up
Yes with no problems.
PostPosted: Wed Nov 23, 2011 8:26 am Up
Check all contacts are clean & try re fitting it.
PostPosted: Wed Nov 23, 2011 8:31 am Up
Have you taken the sender out of the tank and moved the float by hand to see if the gauge moves?
haggis120
PostPosted: Wed Nov 23, 2011 8:52 am Up
I have checked contacts at sender end but dont know about anywhere else.
Yes I had the sender out but gauge did not move but the ohms were changing correctly at the sender.
haggis120
PostPosted: Wed Nov 23, 2011 9:33 am Up
I have just tried plugging the old one back in but it is still not working. Sad
Antknee
PostPosted: Wed Nov 23, 2011 10:05 am Up
Might have broken a connection when you were taking it out?
haggis120
PostPosted: Wed Nov 23, 2011 10:21 am Up
connection at sender is clean with nothing broken and is receiving the 2 1/2 volts.
haggis120
PostPosted: Wed Nov 23, 2011 2:52 pm Up
Found the problem! One of the wires had broken inside its rubber coating just as it comes through the body to the sender unit. It was covered by a small cable tie. Thanks for all the suggestions.
