Online Now [371]:
Visitors: 370
Today: 28311
Total: 128402897
Forums › The Car › Solved 206 Problems › IMMO Problem Peugeot 206 1.4 2006
Go to page Previous  1, 2
millanz
PostPosted: Sat Nov 26, 2011 9:26 am Up
thank you so much Lee... will be back soon with the result Thumbs Up
206 forever.....
millanz
PostPosted: Sun Nov 27, 2011 8:30 pm Up
I have tried to write the dump file. but all failed either to immo off and programmed pin.
Scanning On PP2000 :
Problem detected when transmitting unlock code, Engine immobiliser code can not be read,
ECU status Locked.
Last chance is a file that is still virgin. This afternoon I will try to do it by trying to set parameters via PP2000
regards
206 forever.....
millanz
PostPosted: Mon Nov 28, 2011 12:53 pm Up
virgin file work perfect... just need re-configuration on nearest dealer.. (because my lexia don't have acces to psa Smile ).... will be come back with the result....
206 forever.....
PostPosted: Mon Nov 28, 2011 1:04 pm Up
Should be able to go on replacement parts
millanz
PostPosted: Tue Nov 29, 2011 6:21 am Up
yoaiii bro....
I've returned from the garage. Finally my car was running well, but there are few errors listed in pps.
- Fan can not spin when the temperature is reached, checked via pps (actuator) fan to normal operation both low-speed or high speed.
- The fuel gauge has not shown the correct position.
Thanks for the help of this forum, especially prof. Lee.
Thank you for all your help and time you've given me. salute ...
regards
will be back again for result...
206 forever.....
PostPosted: Tue Nov 29, 2011 6:30 am Up
millanz wrote:
yoaiii bro....
regards
For the fuel gauge reboot the BSI, if that doesn't work then the BSI needs updating.
Is the fan code a permanent or intermittent?
millanz
PostPosted: Tue Nov 29, 2011 7:19 am Up
most likely it is intermittent fault ..
I will perform the procedure BSI Reboot now.
I will check via PPS now ....
206 forever.....
millanz
PostPosted: Tue Nov 29, 2011 8:59 am Up
- Finnally, The Fuel Gauge functioning normally after BSI REBOOT
- Apparently there is no voltage from the altenator. After I checked, there was a short circuit in the altenator caused by oil leaks from power steering. Tomorrow I will disassemble the altenator to look for damage. Most likely it is impacting on the work of fans and headlamp. I did a test with a multimeter reads the voltage 11.75v and I think that's not enough.
Regards
206 forever.....
PostPosted: Tue Nov 29, 2011 9:10 am Up
Regards
When alternator is running you should have >14V on the battery.
How would power-steering oil cause a short though?
It might well have caused damage,or belt slipping but..
PostPosted: Tue Nov 29, 2011 10:44 am Up
Well known issue on TU engined 206's when the head gasket leaks oil, if the oil then gets inside the alternator it can damage / ruin it Wink
Power steering fluid will do the same if it gets inside the alternator.
millanz
PostPosted: Wed Nov 30, 2011 7:59 am Up
there is a leak in the gasket, and it resulted in broken altenator. trying to find a replacement for the altenator regulator, and clean up oil on the altenator.
206 forever.....
millanz
PostPosted: Wed Nov 30, 2011 8:09 am Up
Yoai... you right bro...
For all TU engine users are advised to check the condition of the power steering pump, it is because if there occurs a short circuit caused by leakage of oil into the altenator, it will harm the electrical system and the most severe can result in a fire in the engine room.
Regards
206 forever.....
millanz
PostPosted: Fri Dec 02, 2011 12:32 am Up
SOLVED...........................
206 forever.....
PostPosted: Fri Dec 02, 2011 1:55 am Up
this is a very good thread,and a very important problem,Lee you done a great job as you always do my friend Very Happy
PostPosted: Fri Dec 02, 2011 4:10 am Up
Another satisfied customer.
Page 2 of 2
