Latest: Mr-Koekwaus
Overall: 17125
Online Now [400]:
Visitors: 399
Today: 8302
Total: 99513545
Forums › The Car › 206 Problems › wont tick over
wont tick over
Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8
PostPosted: Sat Nov 26, 2011 11:05 am Up
Any result with this mate?
dumdum0910
PostPosted: Sun Nov 27, 2011 8:44 am Up
fitted the replacement throttle body and it came with a icv and tps , ran fine last week. went out last night and decided to start playing up again. plugged my obd in and it came up idle control systems again... fitted a new icv that i had and still didnt wanna no. i think my car is jinxed
dumdum0910
PostPosted: Sun Nov 27, 2011 1:42 pm Up
When my car does actually tick over properly - matter of seconds it sounds like the exhaust is ppopping . Is this normal ?
PostPosted: Sun Nov 27, 2011 1:55 pm Up
ECU? Confused
dumdum0910
PostPosted: Sun Nov 27, 2011 2:24 pm Up
I'm goin to be taking it to a peugeot specalist next week see what they say
PostPosted: Sun Nov 27, 2011 2:40 pm Up
OK, GL.
PostPosted: Sun Nov 27, 2011 2:56 pm Up
Software update if it hasnt had one already.
dumdum0910
PostPosted: Sun Nov 27, 2011 3:44 pm Up
i think i may do that aswell. im going to be giving this garage a ring tomorrow on my lunch break and see if i can pop in after work and see what they say. also what metre readings should i be looking out for if i connect a multimetre to the icv plug. loom end
PostPosted: Sun Nov 27, 2011 4:00 pm Up
I wouldn't bother.
What would you do even if you had the specialised equipment needed to read a linear-motor circuit,
and found it was at fault?
Just use some contact cleaner on the conectors ECU-end and hope for the best.
Peugeot dealer's sounds like a good idea to me at this stage.
dumdum0910
PostPosted: Sun Nov 27, 2011 4:03 pm Up
ive already cleaned the ecu connectors , worked for about a day . what do you mean read a linear motor circuit
PostPosted: Sun Nov 27, 2011 4:06 pm Up
I think the type of signals found there are a bit more complex than just a voltage you could check with a multimeter.
Pug dealer would be best because they usually have quite good knowledge of PP2000, and latest updates available etc.
dumdum0910
PostPosted: Sat Dec 03, 2011 6:14 am Up
finally given up with this problem got the 206 booked in to a garage to get plugged in and pin point exactly whats going on. will let you all no next weekend when its been looked at
dumdum0910
PostPosted: Sat Dec 10, 2011 8:20 am Up
toke the car to a garage to get checked over for this problem. they said they checked the icv and the wiring , they seem all fine. they disconnected the ecu and plugged it back in and it ran fine. they think it may be a dodgey plug or the ecu is knackered. if it comes back again they will send the ecu for testing and dismantle the plug to see if anything is broken
PostPosted: Sat Dec 10, 2011 8:57 am Up
Has the silicone grease been cleaned out the ecu connectors & plugs yet?
dumdum0910
PostPosted: Sat Dec 10, 2011 11:45 am Up
i cleaned what i could the other week, im going to give it a proper clean tonight
Page 8 of 8
