Online Now [696]:
Visitors: 695
Today: 120095
Total: 157425642
Forums › The Car › 206 Problems › Its not gone well...
Rob2859
PostPosted: Sat Nov 26, 2011 6:34 pm Up
I have a slight issue, one of many I admit Very Happy
I took the handbrake off its base so it wouldn't be so much of a ball ache to take the centre console out as it was last time. Anyway I couldn't get it back on so I thought never mind I will slacken the cable, however...
The nut has had it and just turns on the same point of the thread meaning it won't come off. Also I can't take the cables out the other side as to get the drums off I need to slacken the cable...
Any ideas? Before anyone says it I am not taking a grinder inside my car :D.
Ghosty
PostPosted: Sat Nov 26, 2011 6:39 pm Up
i think its a weldnut under the car, so try getting it re-welded, or get a mate to hold it tight with a spanner while you twist the opposite way, if however you have rounded the thread, try a nut spitter.
Team > Black HDi GTi Stage 1 tuned (140bhp, 235lbs/ft)
Team > Ex HDi D-Turbo owner
W.I.P. > www.206info.co.uk/Foru...rt=15.html
PostPosted: Sun Nov 27, 2011 4:43 am Up
If your handbrake isn't attached to the car, then the cables should be slack already at the drum end.
You could try using a small open ended spanner. Put it over the thread and up against the the face of the nut. Apply lots of pressure onto the face of the nut while trying to slacken it off. If you are lucky the nut will catch a thread and begin slackening off.
Rob2859
PostPosted: Wed Nov 30, 2011 6:44 pm Up
I pushed a screwdriver against the nut while turning it with a spanner and that worked. Thanks for the advice guys Very Happy
