Latest: heikkisj
Overall: 17126
Online Now [74]:
Visitors: 73
Today: 20069
Total: 100282390
Forums › The Car › 206 Problems › Grinding noise from Gearbox in 1st and 2nd
AndyHazy
PostPosted: Sun Nov 27, 2011 8:22 am Up
Hi there, i'm new to this forum but hoping someone can give me some advice.
I bought an 05 reg 206 1.4 HDI from ebay Razz Car was running great and amazing on fuel but I've noticed the gear box makes grinding noises in the first 2 gears when the car is slowing down while in gear.
This has been going on for a while and now the clutch is also on it's way out, revs go up fast but accelarates slow. I'm tempted just to get the clutch changed and new gearbox oil added, It's likely the grinding noise will still happen though and i'll end up having to pay again to have the gearbox taken out and changed to stop the grinding noise. Any suggestions as I believe it is the gearbox bearings making the noise and it probably just needs replacing.
It's done 82,000 and 6 years old
Many thanks
A NEALON
starkie
PostPosted: Sun Nov 27, 2011 9:02 am Up
could quite possibly be the clutch if you say its on its way...could also be the diff....
Starkie =]
ramigojag
PostPosted: Sun Nov 27, 2011 12:13 pm Up
Sounds like the clutch is slipping so will probably need a new clutch but what i would recommend (its happened to me before), while the gearbox is out get it sent to a reputable gearbox repair centre and they will strip it down and refurbish it but they will only do what needs doing.
I had the same problem in my old saxo all the bearings and seals had gone in my gearbox so would grind while setting off, got it back and they had only changed the bearings and seals because that was all that was broken.
PostPosted: Sun Nov 27, 2011 12:28 pm Up
1.4 hdi lump + MA gearbox doesnt make a very good combination Wink
Teebag
PostPosted: Mon Nov 28, 2011 5:02 am Up
Mine does the same. it's the clutch on the way out. unfortunatly at this point you just have no idea as to when it will eventually give up.
my garage inc mod list:
- Antix
