Latest: sparrowdclxvi
Overall: 17139
Online Now [122]:
Visitors: 121
Today: 13470
Total: 113581726
Forums › The Car › 206 Problems › Sony MEX BT3800U
Sony MEX BT3800U
pug206_8v
PostPosted: Sun Nov 27, 2011 1:56 am Up
Hi peepz. I have installed the sony mex bt3800u stereo into my 206 2006 verve. it appears when i unlock the car the stereo automatically turns on and then when i lock the car it automatically turns off. Its not a major problem because it then for saves me the hassle of having to turn it off and on by hand when entering and exiting the car. Any help or ideas as to why this is happening would be grateful.
cheers
glenpring
PostPosted: Sun Nov 27, 2011 4:14 am Up
if you want it so you turn it on and off you have to swap a red and yellow wire at the back of the hu if im wrong some one will let you know
AshH
PostPosted: Sun Nov 27, 2011 6:36 am Up
I thought it was Green & Yellow :/
Team - 180
Team - ATM!!!
starkie
PostPosted: Sun Nov 27, 2011 10:00 am Up
red and yellow...but this is something different to them wires... sound almost like it still thinks your key is in the ignition... does it buzz when you have the door open? or just when you have keys in and door open...
Starkie =]
PostPosted: Sun Nov 27, 2011 11:02 am Up
You have a multiplexed 206 and you have the switched igntion feed connected to the can-bus system. Everytime you unlock the car you wake up the BSI which then sends power to the headunit causing it to come on.
PostPosted: Sun Nov 27, 2011 1:26 pm Up
cheers
Its not wired in correctly, simple.
If your really unlucky other Peugeot / Citroen owners may also be able to wake your stereo up for 3 minutes when they unlock there cars to as your BSI will wake up as it senses an unlock signal nearby then goes back to sleep Laughing
