Online Now [577]:
Visitors: 575
Bots: 2
Today: 55906
Total: 153934534
Forums › The Car › 206 Problems › screeching noise when turning at low speed?
colinn
PostPosted: Fri Nov 25, 2011 10:43 am Up
my car has recently developed this problem - the noise goes away when I straighten up and speed up. sounds like maybe slipping belt
power steering problem? fluid? pump? belt?
PostPosted: Fri Nov 25, 2011 10:45 am Up
does the noise change with the revs?
colinn
PostPosted: Fri Nov 25, 2011 10:47 am Up
no - don't think so - fairly constant pitch and then stops abruptly as I pull away
97browng
PostPosted: Fri Nov 25, 2011 11:16 am Up
I had a very similar issue and it turned out to be a problem with the power steering fluid. I had a hold and all my fluid had drained away.
It may be worth checking the level of fluid and topping up if needed (I got mine from ASDA/Euro Car parts for bout £3 a bottle).
It sorted my problem for a while but in the end I needed to replace a pipe as it was broken. But for you it could be it just needs topping up.
colinn
PostPosted: Fri Nov 25, 2011 11:22 am Up
thanks for the info - will check the fluid level over the weekend.
kit325
PostPosted: Tue Nov 29, 2011 7:57 pm Up
Another cause might be wheel alignment, tyres rubbing noise when turning. Check your wheel alignment, is tyre wear normal? steering pull in to one direction on straight road?
kit
panzer360gti
PostPosted: Wed Nov 30, 2011 1:43 am Up
yeah, tortured tyres! sounds more likely!
Peugeot 206 GTI 137 2.0
PostPosted: Wed Nov 30, 2011 1:58 am Up
If its only recently started it can't be tyres, & if it's only there when your on lock it's probaby not slipping belts. More likely to be a power steering problem like low fluid or pump.
