Latest: flipflap
Overall: 17140
Online Now [450]:
Visitors: 449
Today: 39604
Total: 113839721
Forums › The Car › 206 Problems › Help needed
Help needed
Satmas
PostPosted: Fri Dec 02, 2011 12:01 pm Up
Hi guys, Im a newbie to this site, in need of some help and advice, which I will be most grateful for.
I bought a 206cc 51 plate 1.6 in the summer. I've been fairly happy with it but recently I've noticed when the lights are on, they flicker. It happens every time they are on - back and front, enough for me to notice as I'm driving.
Also, all the dials in my instrument cluster keep 'going wild', no warning lights come on, just the needles dancing around. It doesn't matter whether i'm driving fast or slow. It doesn't always happen on every journey but it is more often than not!
I've checked the battery terminals, they're tight. No hanging cables or wires that i can see.
Please help someone Smile
On my 4th Pug ..... Some might say I'm a glutton for punishment!
PostPosted: Fri Dec 02, 2011 12:16 pm Up
Checked all the earth straps?
Satmas
PostPosted: Fri Dec 02, 2011 12:44 pm Up
Where are they ??
Sorry, yes I know I can be a little vague at times. Confused
PostPosted: Fri Dec 02, 2011 12:50 pm Up
Common one to play up is on the gearbox. But check all the cables you can see leading from places like the engine connecting to the chassis of the car.
Satmas
PostPosted: Fri Dec 02, 2011 1:00 pm Up
Thank you. Will have a look tomorrow in the daylight.
Hopefully that will be the problem. Very Happy
martinius88
PostPosted: Fri Dec 02, 2011 1:16 pm Up
Also a chance it could be the alternator, but check all the earths first.
206 2.0 GTi 138, Eibach: Pro-Kit, torsion bar adjusted, ULTRA angel eyes, Black Lexus rear lights, LED side indicators, Scorpion Cat back exhaust system, K&N Panel filter, theloudest.com speakers fitted all round, Sony HU.
Ibiza Cupra 1.8T 20V, JabbaSport Stage 2 Map, K03s Turbo, Forge 008 re-circ Dump Valve, N249/N111 bypass, H&R Lowering Springs, Forge FMIC. 225BHP @ 1.0 Bar. 0-60--5.6s, 1/4mile--14.2
My Old 206 GTi: www.206info.co.uk/Foru...39589.html
New Car - Ibiza Cupra: www.206info.co.uk/Foru...tml#530454
burnmw
PostPosted: Fri Dec 02, 2011 2:03 pm Up
Check the negative terminal coming off of the battery, remove it completely, make sure it isn't frayed and damaged and that it is well greased, then replace it. If that doesn't fix it, your battery is dying, get it changed before the winter really sets in and kills it completely. I had exactly the same problem, and that was my solution.
The day that Microsoft makes something that doesn\'t suck is the day that they start making vacuums.
Satmas
PostPosted: Thu Mar 22, 2012 3:19 am Up
Hey all. Sorted out the problem. It was a dodgy alternator. All fixed now.
