Online Now [1239]:
Visitors: 1238
Today: 114377
Total: 154804872
Forums › The Car › 206 Problems › Indicator and speedo fault
LeeUK
PostPosted: Sat Dec 03, 2011 6:27 am Up
I've just acquired another 206 for scrap money. It is a 2000 1.4 LX petrol but it has a few faults plus the MOT is due in 2 weeks time.
First fault is the indicators, sometimes they won't cancel when you knock it off yourself e.g the stalk seems to be very sensitive. Also when you go over a bump in the road or something the indicators make a flash/click.
Second fault is the speedo doesn't work. Just sits on 0mph.
Anyone know what the likely cost to get these faults fixed at an indie garage?
Just trying to work out if it is worth getting this 206 fixed as it also needs the brakes seeing too as they are not very responsive - could just need new discs/pads though. It also needs a new handbrake cable I think as it is nearly vertical when applied.
2001 206 1.4i GLX
2001 Megane 1.6i Dynamique 16V
2008 207 1.4 HDI
2014 Focus 1.6 TDCI Titanium Nav
2020 Jaguar E-PACE Chequered Flag D150 AWD + 2002 Ford Focus 1.6 Ghia run-a-bout
PostPosted: Sat Dec 03, 2011 6:49 am Up
Needs a new stalk about £15 of eBay
The whole speedo doesn't work or just the current speed? If just the current speed, a quick check to rule out the sensor is open the door while driving and see if the interior light flashes and/or a beeping noise
johnboy1989
PostPosted: Sat Dec 03, 2011 8:04 am Up
hi lee ive put in a new speedo sensor and mine is still not working now plus since ive done that the mileage has gone off my speedo and ideals what to do next ?? Its going in for a diagonse test on monday cheers john
China Blue 1.6 XS Owner Wink
PostPosted: Sat Dec 03, 2011 8:26 am Up
Best bet is wait till the diag so you can see the live data, then go from there
LeeUK
PostPosted: Sat Dec 03, 2011 8:41 am Up
The interior light doesn't come one and it doesn't make the beeping when door is open with engine on.
2001 206 1.4i GLX
2008 207 1.4 HDI
PostPosted: Sat Dec 03, 2011 8:51 am Up
Are you driving the car or parked?
LeeUK
PostPosted: Sat Dec 03, 2011 9:12 am Up
Parked. But my other 206 beeps and flashes stop when I open a door with engine running. Thought this would have been the same.
Don't want to drive what with the dodgy brakes and indicators.
2001 206 1.4i GLX
2008 207 1.4 HDI
PostPosted: Sat Dec 03, 2011 9:26 am Up
That's because you have the keys in.
How are you possibly going to test the speed sensor parked up? you need to drive it or at least put it on stands and drive it.
LeeUK
PostPosted: Sun Dec 04, 2011 6:15 am Up
Ah I see. I'll have to try it then.
2001 206 1.4i GLX
2008 207 1.4 HDI
johnboy1989
PostPosted: Tue Dec 06, 2011 7:55 am Up
hi lee i just had a diagnose test done and it come up saying nothings wrong with it so what could it be the mechanic thinks that because its not showing the mileage now it could be my speed clocks what you think cheers mate
panzer360gti
PostPosted: Tue Dec 06, 2011 8:05 am Up
Ive got a stalk set for sale for £10 if you want it?
Peugeot 206 GTI 137 2.0
PostPosted: Tue Dec 06, 2011 11:18 am Up
Yeah more than likely your clocks then.
johnboy1989
PostPosted: Tue Dec 06, 2011 4:45 pm Up
panzer you got a picture mate ??
panzer360gti
PostPosted: Wed Dec 07, 2011 2:25 am Up
same as this...
www.ebay.co.uk/itm/Peu...3cbf140391
spud_owen
PostPosted: Wed Dec 07, 2011 2:59 am Up
take the steering wheel cowl off and trying sparying the stalk with a load of wd40, sometimes it will clean up the connection and the stalk wil be all good for another few 10 thousand mile
Honda Accord cdti....205GTI
LACEY AND OWEN ARCHITECTURAL SERVICES
www.laceyandowen.co.uk
