Posted: Fri Dec 02, 2011 12:51 pm |
Firstly, the car has always had a problem since i've had it where occasionally, if you tried to push a lot of power through, the engine management light would come on, and you'd lose the accelerator pedal and the revs would just slowly go down and your speed would drop gradually until you stopped. nothing you can do about it.
Also, at 3000rpm in 3rd gear if you were hitting the accelerator hard, the car would start juddering quite hard and the rev meter would jump back and forth, but not climb further.
Now the car has plodded along quite nicely with sensible(ish) driving for 3 years now, but those things I mentioned have started happening all the time. The juddering happens in all parts of the rev range in all gears at seemingly random times. When the juddering happens, unless I let off the accelerator straight away, that thing will happen where the car cuts the accel. pedal, engine management comes on and just slows to a halt. Sometimes i'll lose the accelerator pedal and get engine management without the juddering first for no reason just cruising along in gear.
Sometimes the car will just stall for no reason at all, I think this only happens while i'm changing gear though. Sometimes the car will stall when it's idling at traffic lights for no reason.
I hope i've explained all this without too much confusion. Please help!! I am more broke than you can imagine and cannot afford to send it to a dealer to get a diagnostic. I need a good rough idea what's wrong before I go to my mate who's a mechanic and we can work it out together.
EDIT: It's a '03 plate 1.4 HDI (pre plex)
Posted: Fri Dec 02, 2011 12:54 pm |
Is it diesel or petrol?
Posted: Fri Dec 02, 2011 12:55 pm |
Edited, 1.4 HDI
Posted: Fri Dec 02, 2011 12:57 pm |
Sounds like it may have something to do with the inlet manifold and a valve that filters out the soot. Not sure if these have ones but had this experiance on a vauxhall and a good clean sorted it out.
Posted: Fri Dec 02, 2011 2:13 pm |
i would check the fuel system, i.e. rail pressure and injectors
Posted: Fri Dec 02, 2011 3:38 pm |
check the air intake hasnt come out at the back of the engine, mine did and every time i put my foot down the air was bypassing the MAP sensor and flagging an error, causing teh car to go into limp mode and not rev past 3k revs, i have the same car as you
Posted: Sat Dec 03, 2011 3:20 pm |
bump
Posted: Sat Dec 03, 2011 3:47 pm |
Why bump when you haven't responded to the suggestions? We aren't mind readers.
Posted: Sun Dec 04, 2011 3:19 am |
I was only hoping for more suggestions. I've checked the air intake and it's fine. So I've had two different suggestions apart from air intake which I am grateful for, but I have no way of checking fuel system /rail-injector pressure myself and there are always plenty of opinions to be had when it comes to undiagnosed car faults.
Why bump? I want to make sure anyone who might have any experience or maybe even a pug technician to see this without it falling down the list.
I know you are a respected and knowledgeable member here, so I mean no disrespect when I ask straight back to you....
Why respond like that with nothing constructive to offer? It's not like i'm spamming
Posted: Sun Dec 04, 2011 5:07 am |
because how are we supposed to suggest anything else when you haven't said what you have and haven't tried. So it's impossible for people to know what to rule out
Posted: Sun Dec 04, 2011 5:11 am |
because if you don't reply what have you checked no one will bother to reply you too.
it's a respect to us
thousand of people on here just ask question and then disappear; don't even bother to update the situation
Posted: Sun Dec 04, 2011 5:18 am |
did you check the boost pressure?
if air intake and boost pressure is fine then it will have to be fuel system problem.
Posted: Sun Dec 04, 2011 8:34 am |
I understand, my apologies I will update with every little development.
How do I check the boost pressure?
Posted: Sun Dec 04, 2011 8:43 am |
It's due it's fuel filter change, i've never done it since i've had the car. What if previous owners neglected it as well, could that be a culprit?
Posted: Sun Dec 04, 2011 1:43 pm |
Possibly .. but I've not changed our 1.4's filter for years and it's fine. Unless the water in diesel light is on.
Have you had it connected to a diagnosis system?? If not, you will just be swapping parts for the sake of it and wasting more money than just on a diagnostic. As it's pre-04 diesel, it's unlikely to like most generic code readers, so you need to find someone with a PlanetPeugeot system or look for a peugeot/citroen specialist in the area.
BTW: I think you will find an '03 1,4 HDi IS multiplex. Unless it's an early one that sat in Pug's storage or a dealers for a while before being registered. If the airbag is clipped on (square holes in back of steering wheel) and the radio stalk is thick and short and not a long thin one, it's mutilplexed.
