Latest: elelectricistadeMateo
Overall: 17127
Online Now [67]:
Visitors: 66
Today: 20559
Total: 100393244
Forums › The Car › 206 Talk › Getting at the inside of rear quarter panel
Go to page Previous  1, 2
hobnob48
PostPosted: Thu Dec 08, 2011 11:29 am Up
Like they say they just pull off. You need to take out the rear bench to get best access. I just took out the bottom bit of the seat.
Also I think the seatbelt is bolted through the card so check that bit too
sillyhilly
PostPosted: Thu Dec 08, 2011 12:09 pm Up
Steel capped boots. Driver door. Sorted.
Hi Mikey Smile
stevesey
PostPosted: Thu Dec 08, 2011 12:33 pm Up
Undo rear sear belt bolt at the bottom, put fingers through hole where front seat belt goes through and pull. That should release most of the front edge, then a bit more fiddling at the back (moving seat around as need).
Had it off 6 months when fitting sub for daughter - she's just come home in tears after clipping a bollard - been out released the front edge of the trim and reached in and popped some of the damage back out, crease left on the upper part though and scratches on the leading edge of the arch. Wing was quite wobbly there if you caught in in the right light anyway (previous owners poorly done accident repairs). Will have to do my best to tidy up at the weekend. With good access to both side I hope I can "improve" the crease sufficiently, not sure how well I'll be able to blow the scratches in with an aeresol, but it is one of the places that gets dirty quickly!!
Andrew
PostPosted: Thu Dec 08, 2011 12:55 pm Up
Thanks for all the info, I'll have a go tomorrow Smile
Steve, hope you get your problem sorted, might be best to ask your mates if they know someone who works in a bodyshop, I'd want to get paint on there as soon as
I'd never damage anyones car, but if I see him again I'd like to see what he would say without his mommy to stand behind.
My 206 thread
www.detailedbyandrew.com
Ali_H
PostPosted: Thu Dec 08, 2011 1:35 pm Up
What was the reg?
kurtis wrote:
Jack4273
PostPosted: Sat Dec 10, 2011 5:10 am Up
Andrewxps wrote:
He said "I don't care, do what you have to do".
Thats a punch in the mouth right there.
Clarion VZ409E 7 inch DVD motorised screen
Sony XMZ-R604 440 watts Channel Amplifier
Vibe Slick 12" 1200 watt Subwoofer
Pioneer TS-A6903i 6 x 9 3-way 350 watts
Raceland 4-2-1 Stainless Steel Manifold
Remapped Ecu
Wolfrace Street Hustle 17"
Very Happy
Click For Da WIP! 206info.co.uk/Garage/m...d=336.html
Page 2 of 2
