Online Now [609]:
Visitors: 608
Today: 123548
Total: 156838495
Forums › The Car › 206 Problems › Car dying
Car dying
darrenskinner1
PostPosted: Fri Dec 09, 2011 11:36 am Up
I think my car is dying,
The last few days the car has been really sluggish at starting, tonight after work I tried to start it an it nearly died, the stereo wouldn't work and had an alarm like beeping noise, also my dash lights dimmed and wouldn't brighten, after I got home, I left the car for 20 mins and everything was normal,
When should a battery's lifetime be over and need changed?
Could this be the distributed or altonator or a plain and simpe battery change or even something more serious?
PostPosted: Fri Dec 09, 2011 11:37 am Up
just get the battery tested......even halford offer free battery test....
ExoVyper
PostPosted: Fri Dec 09, 2011 11:43 am Up
easy way to check is to use a multimeter on the abttery as the cars running
you should see about 14v
if not then your alternator is shot
turn your car off and if your voltage starts dropping quite fast it's your battery thats goosed
AshH
PostPosted: Fri Dec 09, 2011 12:19 pm Up
Battery should be changed every 3years, i think :/
Team - 180
Team - ATM!!!
macj
PostPosted: Fri Dec 09, 2011 12:21 pm Up
Its winter.... old batteries will die as soon as it gets cold
PostPosted: Fri Dec 09, 2011 2:14 pm Up
I agree with that,and the lifetime of the batteries (good brands) like VARTA,BOSCH,DELPHIE,FIAME it's 3-5 if the alt. is in good shape,and you maintain it ,so do as the guys said and check it with multimeter,and you will be sure,and if you want to be sure,let someone else start the car while you test the battery with multimeter,so if the reading drops down to 9-11,then you need a new one for sure.
darrenskinner1
PostPosted: Fri Dec 09, 2011 3:27 pm Up
Ok cool that's alot of help Smile I'll check it out
Ash
PostPosted: Fri Dec 09, 2011 5:04 pm Up
Really Confused
Hmm.. I need to change both of mine then Laughing
Batteries need changing when they no longer hold charge well.
AshH
PostPosted: Sat Dec 10, 2011 3:34 am Up
Ash wrote:
Really Confused
I don't believe in neither Ash. Was what a guy at a garage once said to me. Was going to argue the point but really couldn't be ar$sed.
Hence the :/ face Laughing
Team - 180
Team - ATM!!!
