Online Now [41]:
Visitors: 40
Today: 43641
Total: 117230200
Forums › The Car › 206 Problems › fuel
fuel
Capriman
PostPosted: Fri Dec 09, 2011 1:40 pm Up
I have a 206 GTI 180, When i try and fill it with fuel the pump keeps clicking off after every £5 or |£6. Any idea what maybe causing this?
macj
PostPosted: Fri Dec 09, 2011 1:41 pm Up
Its the nut that holds the trigger Wink
PostPosted: Fri Dec 09, 2011 1:45 pm Up
dont know if it related but everytime i go to shell garage near me, there pumps click off all the time with my van. other pumps have no problem.
Capriman
Very Happy Very Happy Wish it was!! I've only had the car a week and each time i try and put fuel in[differant garages] this happens?? Sad
macj
PostPosted: Fri Dec 09, 2011 1:47 pm Up
My GTi does it if I stick it in too far.....never had that trouble with the Mrs though Shocked
Capriman
PostPosted: Fri Dec 09, 2011 1:50 pm Up
It doesn't make any differance wether i have it pushed right in or just in!!! Laughing Laughing It does just the same, the last 180 never did this
macj
PostPosted: Fri Dec 09, 2011 1:56 pm Up
In a sentence that is meant to sound totally "not rude"..... you are sqeezing too hard
Little and often..... as they say in Japan
Capriman
PostPosted: Fri Dec 09, 2011 1:58 pm Up
Laughing Laughing Laughing
PostPosted: Fri Dec 09, 2011 2:04 pm Up
Try turning the nozzle to a different angle. The pumps shutting itself off because there is a backlog of fuel in the filler neck and the pump thinks the car is full.
I've found with mine, if I hold the nozzle at 5 o clock, it doesn't click off till it's full. I'm buggered if I need fuel at lunchtime though. Rolling Eyes
Big_Rich180
PostPosted: Fri Dec 09, 2011 2:17 pm Up
Just dont put the nozzle in as deep (gigedy), i have the same thing with the lexus.
PostPosted: Fri Dec 09, 2011 3:29 pm Up
try to fill it with the slow (weak)
stevesey
PostPosted: Fri Dec 09, 2011 5:02 pm Up
Similar to macca's suggestion, rotate the nozzle 180 degrees. I've been doing it for years now - had a merc where with the nozzle in the natural position it would cut out as soon as you squeezed the trigger all the way.
Still cuts out at the top, but no annoying cut outs mid fill.
