Posted: Fri Dec 09, 2011 12:40 pm |
I have a 206 GTI 180, When i try and fill it with fuel the pump keeps clicking off after every £5 or |£6. Any idea what maybe causing this?
Posted: Fri Dec 09, 2011 12:41 pm |
Its the nut that holds the trigger
Posted: Fri Dec 09, 2011 12:45 pm |
dont know if it related but everytime i go to shell garage near me, there pumps click off all the time with my van. other pumps have no problem.
macj wrote: |
Its the nut that holds the trigger |
Wish it was!! I've only had the car a week and each time i try and put fuel in[differant garages] this happens??
Posted: Fri Dec 09, 2011 12:47 pm |
My GTi does it if I stick it in too far.....never had that trouble with the Mrs though
Posted: Fri Dec 09, 2011 12:50 pm |
macj wrote: |
My GTi does it if I stick it in too far.....never had that trouble with the Mrs though |
It doesn't make any differance wether i have it pushed right in or just in!!! It does just the same, the last 180 never did this
Posted: Fri Dec 09, 2011 12:56 pm |
In a sentence that is meant to sound totally "not rude"..... you are sqeezing too hard
Little and often..... as they say in Japan
Posted: Fri Dec 09, 2011 12:58 pm |
macj wrote: |
Little and often..... as they say in Japan |
Posted: Fri Dec 09, 2011 1:04 pm |
Try turning the nozzle to a different angle. The pumps shutting itself off because there is a backlog of fuel in the filler neck and the pump thinks the car is full.
I've found with mine, if I hold the nozzle at 5 o clock, it doesn't click off till it's full. I'm buggered if I need fuel at lunchtime though.
Posted: Fri Dec 09, 2011 1:17 pm |
Just dont put the nozzle in as deep (gigedy), i have the same thing with the lexus.
Posted: Fri Dec 09, 2011 2:29 pm |
try to fill it with the slow (weak)
Posted: Fri Dec 09, 2011 4:02 pm |
Similar to macca's suggestion, rotate the nozzle 180 degrees. I've been doing it for years now - had a merc where with the nozzle in the natural position it would cut out as soon as you squeezed the trigger all the way.
Still cuts out at the top, but no annoying cut outs mid fill.
