Latest: DanDan17
Overall: 17128
Online Now [116]:
Visitors: 115
Today: 33146
Total: 100460815
Forums › The Car › 206 Problems › 206 gti 2001 warning light id required please
m4tth3w
PostPosted: Sun Dec 11, 2011 3:04 pm Up
Hi, I have a yellow / amber light at top left of dash which is to the left of the airbag light and comes on with ignition and goes off but then comes back on and stays on constantly,
The symbol is of 2 seated people with seatbelts and possible side airbags either side
sorry about crap pic but it shows where the light is (top left)
PostPosted: Sun Dec 11, 2011 3:07 pm Up
Have you turned your passenger airbag off?
m4tth3w
PostPosted: Sun Dec 11, 2011 3:19 pm Up
No but i tried that, the light stays on whether on or off?
PostPosted: Sun Dec 11, 2011 3:20 pm Up
Looks like you have an airbag fault then I would think
PostPosted: Sun Dec 11, 2011 3:24 pm Up
get the code readed, ebay code reader won't work this time
m4tth3w
PostPosted: Sun Dec 11, 2011 3:34 pm Up
Ive read that there are connection issues under front seats.
Is that worth a check? If so whereabouts are the connections please??
PostPosted: Sun Dec 11, 2011 3:35 pm Up
Right under the seat I think its a green plug
m4tth3w
PostPosted: Sun Dec 11, 2011 3:57 pm Up
thanks
ill have a look
PostPosted: Mon Dec 12, 2011 9:36 am Up
there's 2 plugs under each front seat on non plexed 206's for the side airbags.
The other plug you need to check is the red one.
PostPosted: Mon Dec 12, 2011 10:09 am Up
Crash data or the airbag is switched off.
Loose wires is a flashing airbag light
gazza82
PostPosted: Mon Dec 12, 2011 11:50 am Up
Probably the "squib" .. yes, that's what it's called. It's a part behind the steering wheel. It's not too hard to change, but it's 'kin expensive if you've got a multiplex model! Shocked
PostPosted: Mon Dec 12, 2011 12:03 pm Up
You can't possibly say that without it being fault code read.
And it's non-plexed by the looks of it.
PostPosted: Mon Dec 12, 2011 12:22 pm Up
Its a SIDE airbag fault Rolling Eyes
gazza82
PostPosted: Mon Dec 12, 2011 1:55 pm Up
Oops .... didn't read that bit properly!! Embarassed
m4tth3w
PostPosted: Mon Dec 12, 2011 6:24 pm Up
Is there any way to deactivate the light without a fix because its irritating me?
I've come from a car with just front airbags so I don't really care if the side ones don't work.
