Posted: Mon Dec 12, 2011 6:57 am |
i cant remember but do the front gti6 calipers/discs fit the 206 gti 140?
wheel size is 17' so clearance is ok.
| | ![](images/spacer.gif) |
Posted: Mon Dec 12, 2011 7:00 am |
it will fit but you will need to use gti6 disc and pad too, bolt on.
they are 283x22 disc so even stock 15" alloy will clear the caliper
Posted: Mon Dec 12, 2011 7:01 am |
i have got calipers pads and discs. couldnt remember if they where a direct swop.
cheers
Posted: Mon Dec 12, 2011 8:08 am |
will the abs sensors be the same or different?
Posted: Mon Dec 12, 2011 8:10 am |
Trade Rating: +59
rick-gti wrote: |
will the abs sensors be the same or different? |
ABS is triggered by a ring on the driveshaft, it's not triggered by the calipers.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Mon Dec 12, 2011 8:12 am |
forgot, they are not on the caliper.
