Online Now [1163]:
Visitors: 1162
Today: 37491
Total: 156144781
Forums › The Car › 206 Talk › Retrofitting auto lights/wipers
Forum Index › 206 Talk
skard
PostPosted: Mon Dec 12, 2011 8:37 am Up
As per title - has anyone done this on a multiplexed 206, and if so what's needed?
HDI90
PostPosted: Mon Dec 12, 2011 8:49 am Up
Im guessing , comm2000 , loom, sensor, mirror cowling and then it would need turning on in BSI
GTI 180
PostPosted: Mon Dec 12, 2011 9:14 am Up
Sounds about right to me Thumbs Up
skard
PostPosted: Mon Dec 12, 2011 9:23 am Up
Thanks.
I wonder if the wiper indicator stalk has a hidden button inside (like the trip computer one on the wiper stalk).
loom - where would this go to? if i recall there's a plug in the roof lining next to courtesy light.
has anyone actually done it?
PostPosted: Mon Dec 12, 2011 9:28 am Up
You also need the rain / light sensor bonding on to the windscreen, best idea is get the standard screen replaced with the sensor spec screen so the brackets are already fixed on.
skard
PostPosted: Mon Dec 12, 2011 9:35 am Up
damn, my mrs just got a new windscreen put on a few months back as well. sure there's something i could use to make it stick.
just seeing if it's feasible to be honest, decided not to sell the car (for now) so i need something new on it to stave away the boredom!
think i'll see if there's a hidden button in the stalk first, otherwise it's a no-goer.
thanks again
PostPosted: Mon Dec 12, 2011 9:39 am Up
You also need to check if the loom with connector plug for the sensor is there.
HDI90
PostPosted: Mon Dec 12, 2011 9:41 am Up
on the stalk you just put it on auto, the then you get the message "AUTOMATIC WIPERS ACTIVE" and same for the lights but to activate them just push the button in for 3 seconds
TBH they are a pain in the butt anyway
GTI 180
skard
PostPosted: Mon Dec 12, 2011 9:42 am Up
there is an empty plug up there, think it's green/yellow, but been a couple of years since i last had the light out.
PostPosted: Mon Dec 12, 2011 9:44 am Up
skard hasnt got auto wipers or auto lights fitted YET Wink
They work perfectly fine with the later BSI software versions.
skard
PostPosted: Mon Dec 12, 2011 9:52 am Up
i find auto lights tremendous, ive had my golf over three years and the only time i touch the light switch is when i need the fogs on.
hence, when i get in the 206 the inconvenience of having to turn them on(!) resulting in this thread.
HDI90
PostPosted: Mon Dec 12, 2011 9:54 am Up
Could do with ours updating maybe, the slight change in light or going under a tree will turn them on.
GTI 180
PostPosted: Mon Dec 12, 2011 10:12 am Up
Rain sensor wiring, auto lights, and standard alarm wiring are all part of the same loom and go to the BSI
They go along the headlining, down the a-pillar and connect to a multiplug at the drivers footwell. From there they disperse in different directions to go to their relevant ontrols and then meet back up at the BSI.
PostPosted: Mon Dec 12, 2011 10:15 am Up
Or just buy this - www.raintracker.com/
skard
PostPosted: Mon Dec 12, 2011 10:50 am Up
thanks lee.
seems like far too much effort considering that yesterday it was almost on autotrader.
