Online Now [1289]:
Visitors: 1288
Today: 200642
Total: 155289773
Forums › The Car › 206 Talk › Spraying out doors.
Spraying out doors.
Forum Index › 206 Talk
rick-gti
PostPosted: Tue Dec 13, 2011 10:48 am Up
I plan on spraying from the side bump strips down on both sides. Would I be ok to do this outside in the temperature it is roughly outside now? I have some time off over xmas so want to try and do it then.
clio 197sport owner
PostPosted: Tue Dec 13, 2011 10:50 am Up
No, there's too much moisture in the air for a good finish.
Antknee
PostPosted: Tue Dec 13, 2011 10:55 am Up
its also better if the surface you're going to paint isnt cold
rick-gti
PostPosted: Tue Dec 13, 2011 11:04 am Up
I was thinking that, would I be ok to prep and prime? Ive got a few rust spots on the sills thats all.
clio 197sport owner
ExoVyper
PostPosted: Tue Dec 13, 2011 11:15 am Up
if you prep and prime now you'll just have to do it again after christmas when it's finally dried out Razz
might just be worth waiting pal
HDI90
PostPosted: Tue Dec 13, 2011 12:02 pm Up
i wouldnt mate , ive done it in the past and its come out milky due to it being damp
GTI 180
rick-gti
PostPosted: Wed Dec 14, 2011 1:56 am Up
i will leave it then until it warms up.
clio 197sport owner
Rob2859
PostPosted: Wed Dec 14, 2011 11:24 am Up
If you put rattle cans in hot water for 10 min before you spray it works better too. In this cold the paint is just going to ripple I found that out last winter that was a pain in the a**e.
