Online Now [568]:
Visitors: 567
Today: 139429
Total: 154946694
Forums › The Car › 206 Talk › Gear linkage question on a 2.0 HDI :)
Forum Index › 206 Talk
Jiten
PostPosted: Tue Dec 13, 2011 12:03 pm Up
Good evening guys,
Fantastic forum you have, Fairly new to the 206 scene.
I have jus recently purchased a 2001 2.0 HDI off ebay, car is in fairly good nick except for the gear changes, I find i sometimes struggle to get into gears unless i force it quite a lot... Doing a search the could well be worn linkages... I intend to replace these, my question is....
Are the gear linkages the same for the MA gearbox and the BE4r gearbox?
Also is it fairly straight forward to fit? I am fairly mechanically minded!
Thanks for any help!
Pug 2.0 hdi
PostPosted: Tue Dec 13, 2011 12:06 pm Up
no, they are different.
and yes; only if you got small hands, space are quite tight down there.
and you know, gear shift on 206 is sh**.
HDI90
PostPosted: Tue Dec 13, 2011 12:07 pm Up
2.0 petrol and diesel are the same, 1.1, 1.4 , 1.6 use the longer type links
on the HDI its a little harder as you have to do them from under the car unless you take the airbox and pipe coming from the turbo off
i did all 3 last week on mine i got the uprated ones and feel alot better now
www.ebay.co.uk/itm/Peu...4aafae957a
GTI 180
Jiten
PostPosted: Tue Dec 13, 2011 12:15 pm Up
Thanks for the quick response.
HDI90 - do you have the BE4r gearbox? And would the ebay links be sufficient for that box?
Thanks again
Pug 2.0 hdi
PostPosted: Tue Dec 13, 2011 12:17 pm Up
they are the right one, better than the oem one too
Jiten
PostPosted: Tue Dec 13, 2011 12:21 pm Up
Fantastic!!! Off to ebay!!!
Pug 2.0 hdi
PostPosted: Tue Dec 13, 2011 4:43 pm Up
Unless its a much newer 1.1 or 1.4 petrol as they will use a cable instead Wink
