Latest: DanDan17
Overall: 17128
Online Now [60]:
Visitors: 59
Today: 34822
Total: 100462484
Forums › The Car › 206 Problems › Oil leaking from head gasket side
deanparkr
PostPosted: Wed Dec 14, 2011 5:09 am Up
My Headgasket is leaking oil from one of the sides (I think nearest the alternator). I have been quoted £500 to fix the problem.
Just wondering from the experts if this is a good deal? Also am I right in understanding that it does not need skimming if it is just leaking from the side?
No evidence of murky coolant or mayo in the oil cap.
Thanks for any tips Smile
2002 1.4LX
paul_c
PostPosted: Wed Dec 14, 2011 7:29 am Up
If it does need a new head gasket, then not skimming the head while its off is false economy, but if you're desparate to save money its possible to skip this.
PostPosted: Wed Dec 14, 2011 9:09 am Up
Either get the head skimmed OR look forward to changing the head gasket again very soon.
Choice is yours.
£500 for a TU head gasket replacement Shocked is that a Peugeot main dealer quoting on the price?
deanparkr
PostPosted: Wed Dec 14, 2011 11:05 am Up
Yeah its a main dealer. I always thought from reading these forums from time to time that a head gasket skim is only needed if the engine warps? Is this not the case?
The current leak does not result in oil mixing with coolant etc - does it still need skimming?
2002 1.4LX
paul_c
PostPosted: Wed Dec 14, 2011 11:14 am Up
The way to tell if it needs skimming or not, is to measure it for flatness. Just becuase symptoms do not reveal themselves now, doesn't assure the longevity of it. If you get a new head gasket, and head skimmed, and head rebuilt, there's no reason it won't last a long time (8-10 years+). Effectively, its a top end engine rebuild.
deanparkr
PostPosted: Wed Dec 14, 2011 11:22 am Up
Thanks for that paul_c that helps clear it up :). I'll speak to the garage about your comments and see what they say.
I definitely don't want to be spending money on something that wont last a reasonable amount of time Shocked
2002 1.4LX
PostPosted: Wed Dec 14, 2011 12:01 pm Up
Find a decent garage, A TU lump is a simple / stone age design, any decent garage will be able to replace the head gasket far cheaper then a Peugeot main dealer.
