Online Now [453]:
Visitors: 452
Today: 108161
Total: 157129961
Forums › The Car › 206 Talk › ECU plug
ECU plug
Forum Index › 206 Talk
Go to page 1, 2, 3  Next
dumdum0910
PostPosted: Sat Dec 10, 2011 12:45 pm Up
are you able to buy replacement fastners for the ecu plugs. the grey bit that clips in to the ecu has snapped Sad
PostPosted: Sat Dec 10, 2011 12:50 pm Up
Nope. Need to buy the whole plug.
What ECU, number of plugs and number of pins is it?
dumdum0910
PostPosted: Sat Dec 10, 2011 12:51 pm Up
not sure what ecu, its 3 plugs and not sure on how many pins
PostPosted: Sat Dec 10, 2011 12:55 pm Up
You need to find out
Put it this way...there are 4 different ECU's on the 2.0HDi
dumdum0910
PostPosted: Sat Dec 10, 2011 12:57 pm Up
i will look tomorrow then.
dumdum0910
PostPosted: Sun Dec 11, 2011 10:24 am Up
this is the ecu :
- 24 pins in there
dumdum0910
PostPosted: Mon Dec 12, 2011 2:22 pm Up
has any 1 got a part number for this? as ill go to peugeot tomorrow after work
dumdum0910
PostPosted: Wed Dec 14, 2011 11:46 am Up
this thread can now be closed. i went in to peugeot on the way home and you cant just buy the plug and they want £220 for the loom
PostPosted: Wed Dec 14, 2011 12:05 pm Up
Is there a makers name on the plug?
You will be able to get the plug from somehwere BUT you also normally need a special tool which are pretty pricey for removing / inserting the connector pins in to the plastic socket.
dumdum0910
PostPosted: Wed Dec 14, 2011 12:15 pm Up
it wont be me fitting it, ill supply the plug then take it to the garage i toke the 206 to last weekend to fit it :). and im not sure if there's a makers name. ill have a look when i get 2 mins
PostPosted: Wed Dec 14, 2011 2:50 pm Up
Paper clips are fine for pushing down the barb on the terminals on ECU plugs.
Service box normally lists plugs and terminals for the loom. That's how I managed to get new terminals for my crank sensor plug.
You might just need to trawl through the pages to identify the plug you need. Look at the Fastenings, Fixing and Connectors catalogue.
PostPosted: Wed Dec 14, 2011 2:58 pm Up
Looks like this is what you need.
dumdum0910
PostPosted: Thu Dec 15, 2011 12:25 am Up
that looks similar to what i need yes. cant really tell with the small pic.
PostPosted: Thu Dec 15, 2011 9:44 am Up
Part number 6541 Y8 @ £5.59
PostPosted: Thu Dec 15, 2011 9:45 am Up
That should confuse / annoy the dealer when he goes in to order it Laughing
Page 1 of 3
