Online Now [358]:
Visitors: 357
Today: 110752
Total: 157299873
Forums › The Car › 206 Problems › Steering wheel airbag ?
Go to page 1, 2, 3  Next
twitch169
PostPosted: Thu Dec 15, 2011 3:42 pm Up
Hi all i have got 206 1.6 8v xs and its got a leath stitch 206 steering wheel off a gti i think. But im just wondering my car does not have a airbag light come up on check when putting on the ignition so my concern is did the car come with one when new or has some privous owner put this on to look good ?
peugeot 1.6 xs lowerd with black 15\" alloys custom chrome grill painted red dash and trim
PostPosted: Thu Dec 15, 2011 3:45 pm Up
ALL UK spec 206's came with at least a drivers airbag & seatbelt pretensioners.
Check the bulb in the instrument panel hasnt blown or been removed Wink
You need to fix it ASAP as the mot test will fail it from 2012 if the airbag light is missing / on all the time / doesnt go through correct check sequence.
Bulb has been took out or blown
HDI90
PostPosted: Thu Dec 15, 2011 3:52 pm Up
Taken out id say to hide somthing
GTI 180
PostPosted: Thu Dec 15, 2011 3:54 pm Up
The non plexed 206 airbag system is pretty basic.
Only faults you hear of are dodgy electrical connections & rarely when the rotary switch fails the drivers airbag can be fired when the horn push is operated, i've heard of 2 doing this so far over the years Laughing
twitch169
PostPosted: Thu Dec 15, 2011 3:57 pm Up
O well got a momo steering wheel and boss to fit anyway would that bein on fail a mot
PostPosted: Thu Dec 15, 2011 4:01 pm Up
Yes, as the airbag wont be fitted so it will be an automatic mot fail.
Most people on here would rather have the working airbag system as it does a good job Wink
Pop the instrument cluster out & check / replace the bulb for the airbag warning light & see if the system is working correctly.
twitch169
PostPosted: Thu Dec 15, 2011 4:17 pm Up
Well i just checked mot testing and they dont check the airbag system and u can have a steerin wheel without a airbag they just check it secure and wont hurt the drivers hands when in use
gazza82
PostPosted: Thu Dec 15, 2011 5:07 pm Up
They will from next April .... all warning lights will mean a fail. No cat, fail.
PostPosted: Thu Dec 15, 2011 5:12 pm Up
Depends where you have it mot'd.....
twitch169
PostPosted: Fri Dec 16, 2011 2:21 am Up
No airbag light on dash tho so cart fail it because it not on
iainlovatt
PostPosted: Fri Dec 16, 2011 5:43 am Up
i would say the bulb has been taken out because it kept flashing at the previous driver!
(My Garage)
PostPosted: Fri Dec 16, 2011 6:02 am Up
Yeah but it should come on for the systems check Wink
gazza82
PostPosted: Fri Dec 16, 2011 7:34 am Up
And if it doesn't comeon during the test check ... MOT fail from next April as well ...
And OK Lee, depends who does it, but then I tend to get mine done by a legit and honest tester! Wink And if you get it down BEFORE April, it will pass and you have another year to worry about it! Wink
paul_c
PostPosted: Fri Dec 16, 2011 7:40 am Up
You might not have a year to worry about it if you crash.
Page 1 of 3
