Online Now [1076]:
Visitors: 1075
Today: 44878
Total: 152691264
Forums › The Car › 206 Problems › Gear stick wobble under acceleration
PostPosted: Sat Dec 17, 2011 6:08 am Up
Car: 206 1.4 look 52 plate multiplexed.
I noticed this morning after having new tyres fitted that the gearstick moves back and forth in a regular motion under acceleration. It moves backwards and forwards more quickly as speed increases.
Any ideas on what could be wrong?
macj
PostPosted: Sat Dec 17, 2011 6:10 am Up
does the steering shake
PostPosted: Sat Dec 17, 2011 6:11 am Up
Out of shape tyre?
Wheel not fitted correctly?
Could be tyre balance but that would be more of a vibration issue.
PostPosted: Sat Dec 17, 2011 6:14 am Up
No steering wobble, tracking seems ok because it doesnt move about under braking so far.
The tyres are Bridgstone Potenzas, literally fitted a hour ago by National Tyres.
PostPosted: Sat Dec 17, 2011 6:20 am Up
Take the n/s front wheel of & stick the spare on as a test to see if it improves it, if it doesnt then swop the spare over to the o/s front & try again.
Im guessing out of shape tyre.
macj
PostPosted: Sat Dec 17, 2011 6:23 am Up
Or just take it back and tell them you have a wobble.... saves getting the tools out yourself
PostPosted: Sat Dec 17, 2011 6:35 am Up
Ok, thanks for the replies guys Smile
simon_p
PostPosted: Wed Jan 11, 2012 3:08 pm Up
did you get a remedy for this?
Peugeot 206cc SPL build
2011 - 2 vibe 12" spaces, 38hz ported box, 2.5k Ground zero Nuclear mono - 141.2db @ 38hz
2012 - GZ Nuclear 12"s, 33hz box, 2 x 2.5k GZ Nuclear monos, 8" GZ comp mids, 4" GZ tweeters - 144.0db @40hz off 1500wrms
build thread -http://www.206info.co.uk/Forums/viewtopic/p=486554.html#4865540
