Posted: Mon Dec 19, 2011 10:00 am |
Whilst investigating under the bonnet to find an oil leak I have discovered this on the near side of the car (right as you look at it). Any ideas what this is and if I need to connect the two wires. Although it looks like they should go together they dont seem to be a perfect fit. Very mysterious!
Also I have identified a tiny oil leak on the front off-side of the engine (left looking into the bonnet). The oil leak is falling just by the side of the power steering pulley / belt (?). Currently its a very small leak and just wondered if it is common for 206's to get a leak in this place?
Garage are suggesting head gasket replacement but now that I have seen the leak I am not so sure!
Posted: Mon Dec 19, 2011 10:11 am |
those connections are for different lights. dont worry about them
head gaskets hardly ever leak oil externaly more likely internaly bu would smoke alot you would know about it, check your coolent and oil cap for caramel looking substance.
its more likley rocker cover leaking or the power steering.
| *DEAD*206 Gti 138
Toyota Celica T sport 205 BHP | |
Posted: Mon Dec 19, 2011 10:14 am |
The grey 3 pin connector is for the crystal H7 head lamp.
The grey 2 pin connector looks like the one for front fog lamps.
Posted: Mon Dec 19, 2011 10:29 am |
MrBSI wrote: |
The grey 2 pin connector looks like the one for front fog lamps. |
Ah I have neither of those so that makes sense Thanks!
As far as I can see the leak is external and the oil is sitting on the metal bar just to the right of the power steering thingy. Have cleaned the oil away now to judge how much leaking is going on. I'll post another picture sometime.
Posted: Mon Dec 19, 2011 10:32 am |
Is the oil leak coming from around the silver rocker cover at the very top of the engine?
Posted: Mon Dec 19, 2011 10:37 am |
This isnt my car but shows I have highlighed the area where the oil was found:
Based on that I presume it is coming from the top cover and dropping down (maybe?)
Posted: Mon Dec 19, 2011 10:40 am |
look for the highest point you can see the oil and its probabbly comeing from that gasket on the rocker covery, they crack and leak, get a new one and go from there
| *DEAD*206 Gti 138
Posted: Mon Dec 19, 2011 10:43 am |
Trick with the TU rocker cover gasket, make sure you use the correct torque on the rocker cover bolts.
Do them up to tight & the rocker cover will bend slightly like a banana which make the oil leak start again
Posted: Mon Dec 19, 2011 10:49 am |
Interesting, I cant identify any oil at the silver cover.
Will check back in a few days and see precisely the leak is coming from. Probably should have looked harder the first time round!
Posted: Mon Dec 19, 2011 12:11 pm |
Posted: Mon Dec 19, 2011 12:20 pm |
Head gasket, TU lumps always seem to leak there, its a common problem,
Just keep an eye on it, if it gets worse / starts leaking oil in to the alternator then its time for a new head gasket.
Posted: Mon Dec 19, 2011 1:14 pm |
Thanks for the words of wisdom Mr BSI!
Posted: Mon Dec 19, 2011 3:30 pm |
MrBSI wrote: |
I agree with him
