Latest: DanDan17
Overall: 17128
Online Now [96]:
Visitors: 95
Today: 20669
Total: 100418839
Forums › The Car › 206 Problems › 2.0 hdi brake failure
Will.HDI
PostPosted: Mon Dec 19, 2011 8:19 am Up
ok so just been out in my 206 coming down a slight hill and had to brake quite heavily for another car, braked fine for a second then my foot hit the floor! so after peeling my girlfriend off the roof tried it again and no brakes unless i push hard to the floor it also pulls hard to the right and also only the front drivers wheel seems to brake and lock up, handbrake still working fine though but the light stays lit. any help or suggestions please
"PIN IT, YA FAIRY!!"
leigh_boy
PostPosted: Mon Dec 19, 2011 8:34 am Up
a leak from your break system check the resivor under the bonnet , check around the abs to make sure the pipes arnt leaking, and look at the calipers and discs for leaks and signs of wear
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
Will.HDI
PostPosted: Mon Dec 19, 2011 10:48 am Up
cheers for reply, found the leak from passenger side rear drum just took it apart quickly and the cylinder is bummed, ill get it sorted tomorrow.
PostPosted: Mon Dec 19, 2011 10:49 am Up
Pair of rear wheel cylinders & set of rear brake shoes will be the ideal fix.
Common issue with the 206 Wink
Will.HDI
PostPosted: Mon Dec 19, 2011 11:00 am Up
ahh is it, so should i get new cylinder for both sides? i was going to get a new one for just the passenger side as thats where the leak was coming from. also thought id mention the last couple of days the brake pedal has been solid when first starting in the morning but after ten minutes it frees up and works fine again
leigh_boy
PostPosted: Mon Dec 19, 2011 11:02 am Up
dont skimp on brake's if you can afford to do both do it but you will defo need atleast a cyclinder and a set of brake shoes as they will now be contiminated.
*DEAD*206 Gti 138
Will.HDI
PostPosted: Mon Dec 19, 2011 11:08 am Up
yea i get that, new cylinder and shoes but i was just going to do passenger side due to leak being there but ill do both sides if its recomended
PostPosted: Mon Dec 19, 2011 11:27 am Up
Brake shoes MUST be replaced in complete axle sets!
If one wheel cylinder has leaked the other wont be far behind it.
Your already gonna have to take the other drum of to fit the new brake shoes so while your in there it makes sense to replace the other wheel cylinder Wink
