Posted: Wed Dec 21, 2011 5:08 pm |
car will take a while to start fires up on 3 or maybe 2 cylinders then cat faliure flashes up then car starts dying what can i do??
Posted: Wed Dec 21, 2011 5:20 pm |
well you need to get the code read first
Posted: Wed Dec 21, 2011 6:12 pm |
might be sumthing simple like sparkplug r shot, maybe its frowing you emissions off
Posted: Wed Dec 21, 2011 7:37 pm |
Make sure your 02 wires are not corroded. My second one was and my car ran on 2 cylinders.
Posted: Thu Dec 22, 2011 3:59 am |
iv had the plesure of replacing the plugs and tryed unpluging lambda sensors only thing i think now is to take the cat off and clean it out
Posted: Mon Jan 02, 2012 12:13 am |
to anyone with the same probably it turns out my coil pack died and put strain on the injectors to pump more petrol in and now have to replace number 1 and 3 injector and lambda sensor ....... TO ANYONE WHO HAS AN XSI THIS "IS" YOUR probably AS THE GARAGE I TOOK IT TO HAVE HAD EXACTLY IDENTICAL IN THE LAST 6 YEARS ............
