Latest: Worthy967
Overall: 17143
Online Now [577]:
Visitors: 576
Today: 109158
Total: 114232725
Forums › The Car › 206 Problems › Speedo Trouble
Speedo Trouble
puggy206
PostPosted: Thu Dec 22, 2011 1:07 pm Up
Last month i decided to change my alloys to some aftermarket ones, so my standard wheels were 195/50/r15, and so i bought some wheels that was close to them 195/55/r15 and i have noticed that my speedo has become about 5 mph out. i know that changing the size can alter it but all ive changed is the width, what could have cause the speedo to become wrong?
Thanks All
Citroen DS3
D-style +
1.6 VTI
HDI90
PostPosted: Thu Dec 22, 2011 1:18 pm Up
All speedos will be out, 3mph is the normal
GTI 180
puggy206
PostPosted: Thu Dec 22, 2011 1:33 pm Up
i understand that most speedos are out anyway and at higher speeds they get worse, but it used to be pretty accurate, its only after i changed the wheels the speedo went out.
Citroen DS3
D-style +
1.6 VTI
PostPosted: Thu Dec 22, 2011 1:40 pm Up
Different radius and circumference affects the speedo
Fit 205/40/17 or 185/60/14 and your speedo will be accurate.
PostPosted: Thu Dec 22, 2011 2:18 pm Up
www.206info.co.uk/Foru...ratio.html
What are you comparing the speedo against?
puggy206
PostPosted: Thu Dec 22, 2011 2:30 pm Up
My tom Tom but I'm not sure how accurate they are
Citroen DS3
D-style +
1.6 VTI
PostPosted: Thu Dec 22, 2011 2:31 pm Up
A lot more accurate then the 206 speedo.
Tom tom will be using GPS.
puggy206
PostPosted: Thu Dec 22, 2011 2:34 pm Up
oh well in a way its on the good side of beiong wrong (saying im doing 40 when im doing 35) means im less likely to get a ticket... more likely to p**s other drivers off though haha
Citroen DS3
D-style +
1.6 VTI
-Dave-
PostPosted: Thu Dec 22, 2011 2:53 pm Up
Trade Rating: +36
Mine is out about 4mph but when you consider the price to get it sorted you soon get used to it.
Ex 206 Owner.
welshie87
PostPosted: Thu Dec 22, 2011 5:38 pm Up
remember there is a short delay in readings from sat navs plus with 3-4 mph speedo's are likely to be out best bet is to find somewhere we're there are laser speedos which give a speed reading we have them around here the others pug is about 3mph so your reading isnt to bad. And your right with it being out by 5 mph very rare you will get yourself a speeding ticket. Getting your alloys might save you money in the long term lol
Back and posting after along time away
PostPosted: Thu Dec 22, 2011 6:19 pm Up
mine was spot on with 195/55/15 tyre
Rob2859
PostPosted: Thu Dec 22, 2011 9:49 pm Up
I don't have a speedo at all I know how fast I am going by the RPM Very Happy
Ash
PostPosted: Fri Dec 23, 2011 10:09 am Up
That has the same issue as the speedo..
Rob2859
PostPosted: Sat Dec 24, 2011 6:31 pm Up
Yes I know I was just saying. Also there is a very easy and free way to adjust your speedo nobody has mentioned yet Wink
Ash
PostPosted: Mon Dec 26, 2011 6:33 pm Up
If you mean taking off the needle and moving it, it won't work either as the amount of miles per hour that is out is a percentage so it varies with speed. Non linear..
