Latest: elelectricistadeMateo
Overall: 17127
Online Now [64]:
Visitors: 63
Today: 21455
Total: 100394134
Forums › The Car › 206 Problems › engine miss fire.
engine miss fire.
DavidPCoates
PostPosted: Mon Nov 28, 2011 12:21 pm Up
After recently replacing the head gasket I took the car for a test drive, initially it felt great, but then started spluttering, eventually cutting out.
While the engine was running it seemed the top end was pressurized, where as the bottom wasnt.
The RAC guy thought it was the head gasket again, I recognise it may be this because I didnt skim the head, but why would it run great then suddenly badly?
Could it be the drive belt may have jumped pne notch? (long shot but ever the optimist).
The car is 1.4 petrol.
Dave
Dave Coates
PostPosted: Mon Nov 28, 2011 12:28 pm Up
if the belt was tensioned right than it could jump a tooth.
tailhappy
PostPosted: Thu Dec 22, 2011 8:44 pm Up
if the belt wasnt tensioned it would jump a tooth and if you didnt skim the head or clean the block / head then water / oil will easily get through and f*** another head gasket knowing this as when i trained as a mechanic i had to fix a few (bodges) 1 including a cerial box (it dosnt work on newer cars guys)!!
jamie bennett
