Latest: Worthy967
Overall: 17143
Online Now [516]:
Visitors: 514
Bots: 2
Today: 57014
Total: 115247446
Forums › The Car › 206 Talk › Cruise control
Cruise control
Go to page Previous  1, 2, 3 ... 23, 24, 25 ... 34, 35, 36  Next
skard
PostPosted: Thu Mar 11, 2010 1:24 pm Up
Joe wrote:
G. What model do you have? The garage told me I have the switch but I've had a look and next to the clutch switch is hole. Is that were the switch is ment to be?
yep that's where the brake switch would be.
maybe they're hidden under the carpet in true pug fashion.
wagsy206
PostPosted: Thu Mar 11, 2010 3:02 pm Up
so there has to be a brake and clutch switch??
was out testing my pugplanet Very Happy . same one as skards and it works perfectly.
got 4 engine faults. 2 to do with the camshaft sensor (i think) and 2 to do with the air sensor (too much air, and not enough air).
activated the seat belt warning light, overspeed warning, changed the MFD display, activated the auto-rear wiper on reverse (which ill need to check)
Wagsy206
old post count: 5000+
Team: Honda Accord
wagsy206
PostPosted: Thu Mar 11, 2010 4:46 pm Up
skard wrote:
i looked today without the stalk plugged in (i'm adding new keys to the 206) and the option in instrument cluster wasn't even present. the stalk has to be in first.
has anyone got the brake switch fitted as standard? there's a plate there ready to house it in mine.
where is the brake switch located??
Wagsy206
Team: Honda Accord
Brian
PostPosted: Thu Mar 11, 2010 4:48 pm Up
Trade Rating: +31
Passenger side at the bulk head i think it's a white thing i think. It'll look like a switch. Never actually looked for it before Laughing I hope you enjoyed my vague advice.
Regards,
Brian
Rolling On The Floor Laughing
wagsy206
PostPosted: Thu Mar 11, 2010 4:50 pm Up
vague, but probably more than helpful, lol.
ill have a look tomorrow for it. ill be doing a diagnostic on my dads car as well, so i could maybe check the settings for the cruise control settings.
Wagsy206
Team: Honda Accord
Joe
PostPosted: Thu Mar 11, 2010 6:03 pm Up
Regards,
Brian
So its not above the pedal then?
1.6 HDi. . . . The worst engine ever made
Kratos
PostPosted: Fri Mar 12, 2010 7:01 am Up
yeah that seems wierd , should be on the brake pedal , so when you hit the brakes cruise control disengages , like most other cars thats how it works, correct me if im wrong though.
Previously 206 GTI SP.
Now SUBARU IMPREZA 2.0 AWD
skard
PostPosted: Fri Mar 12, 2010 8:03 am Up
it should be above brake pedal, on the same mounting as the clutch switch.
Dillon
PostPosted: Fri Mar 12, 2010 8:04 am Up
Staff - Dillon
The 206 being a French designed car the servo and master are on the near side of the car, a bar runs from the pedal along the bulk head on right hand drives.
Brian
PostPosted: Fri Mar 12, 2010 8:11 am Up
Trade Rating: +31
I thought the plug next to the clutch pedal is to do with the clutch for the the CC is it not? Otherwise EVERYONE would have that switch and there wouldn't have been 5 pages of "yes i have that switch" and "no i don't have the switch" earlier on in this thread.
By brake switch are you guys merely talking about the switch which turns the rear brake lights on/off Question
Something needs clearing up as i'm confused now.
Hankins
PostPosted: Fri Mar 12, 2010 8:58 am Up
You should either have a single brake switch with 4wire coming from it or 2 brake switches with 2 wires coming from each.
If you have a just a single brake switch with two wires coming from it then cc wont work. You will have to get a second switch and find the second cable in the car.
skard
PostPosted: Fri Mar 12, 2010 11:04 am Up
i have the 2 pin switch on the passenger side footwell, but not the additional switch that seemingly goes above the brake pedal. if you check a link i put to a french 307 site on page 21 you'll see pics of what i mean.
i think a switch has to be installed above the brake, run through the firewall and into the engine ECU.
Joe
PostPosted: Fri Mar 12, 2010 11:12 am Up
Im lost now, might just knock it on the head
wagsy206
PostPosted: Fri Mar 12, 2010 12:00 pm Up
same here joe.
if someone could take a picture of the switch in question and post it up, it would be very helpful.
Wagsy206
Team: Honda Accord
skard
PostPosted: Fri Mar 12, 2010 12:15 pm Up
there's a link to a pic on page 21 from me, but the 307 site i'm referring to has gone down at the minute.
in the passenger footwell, attached to the metal bar you'll see a switch. the one i am referring to is another one in addition to this.
keep trying the link and when it's up again you'll see what's going on.
Page 24 of 36
