Online Now [253]:
Visitors: 251
Members: 1
Today: 71026
Total: 156307530
Forums › The Car › 206 Problems › 206 1.4 missfire and rough idle problems
chris_loader
PostPosted: Thu Dec 22, 2011 11:00 am Up
hi im new to this forum but im having some problems with my girlfriends 206 as its missfires and has a really bad idle
i get these codes come up:
p0270 cylinder 4 injector
p0351 coil 1
p0108 map sensor
p0113 intake air temp
i got a new coil pack and no joy and the missfire has been happening for a long while but it onli happens for about a day and then wont happen again for a few months
any advice or anyone had these problems
206cc 2.0 16v
chris_loader
PostPosted: Thu Dec 22, 2011 11:05 am Up
a while a go i changed the injectors round so its not the injector at fault and i also cleaned all off the connectors and the problem is still there
206cc 2.0 16v
peteleton
Had the same problem and kind of the same codes. Replaced the map sensor coil pack and had the enjectors changed and now its sweet as a nut. Give the map sensor a clean or replace it as they are cheap. and give the jets a clean.
What plugs you running?
peteleton
PostPosted: Thu Dec 22, 2011 11:09 am Up
oh yes and change the plugs lol
chris_loader
PostPosted: Thu Dec 22, 2011 1:20 pm Up
i dont know what plugs they are as it dont say on them but they were new about 4 months ago same with the coil pack where is the best place to get injectors and how much am i looking at spending also what plugs are best for the car
206cc 2.0 16v
PostPosted: Thu Dec 22, 2011 1:21 pm Up
Bosch spark plugs.
Check / replace the plugs before you start looking at replacing injectors.
chris_loader
PostPosted: Thu Dec 22, 2011 1:28 pm Up
i replaced the plugs and coil pack last time and problem was still there, there is a french breakers near to me ill see what they have got is there anyway of testing a injector
206cc 2.0 16v
PostPosted: Thu Dec 22, 2011 1:33 pm Up
What make of plugs?
What make of coil pack?
Unless its Bosch plugs with Bouricord coil your just wasting your time.
chris_loader
PostPosted: Thu Dec 22, 2011 1:43 pm Up
they were bosh plugs but the old coil pack was that make but the newish one does not have a make on it
206cc 2.0 16v
PostPosted: Thu Dec 22, 2011 1:45 pm Up
So you changed a Bouricord coil pack for one that has no makers name on it? Confused
What was wrong with the Bouricord coil pack? they never go wrong.
chris_loader
PostPosted: Thu Dec 22, 2011 1:49 pm Up
well i changed it when it frist started missfireing back in may and also changed the plugs as i thought that would be a good place to start but then it didnt fix it but since this the car will run fine for months at a time but then intermitenetly missfire but then today she went to work and it was missfiring and realli bad idle so i unpluged the map sensor and that made it so she could get the car home
206cc 2.0 16v
chris_loader
PostPosted: Thu Dec 22, 2011 2:47 pm Up
i will go and get some new plugs tomorow and put the original coil pack back on with a new map sensor hopefully some where has one in stock
206cc 2.0 16v
chris_loader
PostPosted: Mon Dec 26, 2011 7:36 am Up
have just changed the plugs and map sensor and it was running fine for about 5 min then starting miss firing again so it might be injectors then maybe
206cc 2.0 16v
chris_loader
PostPosted: Tue Dec 27, 2011 5:20 am Up
i changed the injectors round and took it for a run and it always p0270 cylinder 4 injector so it cant be the injector can it must be something to do with the wireing of the injectors
206cc 2.0 16v
