Online Now [441]:
Visitors: 440
Today: 100877
Total: 154912525
Forums › The Car › 206 Problems › Jerking car, but only without acceleration...
panzer360gti
PostPosted: Wed Dec 28, 2011 10:25 am Up
When I am rolling down the road, no acceleration and clutch up, the car has started "jerking" slightly, as if Im tapping the brake really lightly, aside from a brake problem could there be another problem??
Peugeot 206 GTI 137 2.0
kingdom200
PostPosted: Wed Dec 28, 2011 10:39 am Up
clutch judder.....warped flywheel common problem
PUG1OFF Cat Cams/ ECU project
PostPosted: Wed Dec 28, 2011 10:49 am Up
You mean at a cruise? This is where the lambda sensor is used to run the engine at best mixtures for the cat to work.
panzer360gti
PostPosted: Wed Dec 28, 2011 12:10 pm Up
Im thinking it might not be clutch, its too intermittent, doesnt do it regularly, more like occasional, and I have got some cat rattle where I think the olive is loose at the manifold, so more likely exhaust problems.
Also had to swap to my induction air intake as my flat filter was filthy. New filter tomorrow and tighten up the cat, see if it improves.
Also got a worn brake pad (one side) so Im answering my own crap I suppose but always best to put these things out there Smile
