Posted: Wed Dec 28, 2011 1:45 pm |
can you install a new manifold on a gti 138 without taking out the engine?
Posted: Wed Dec 28, 2011 1:49 pm |
and by new i mean a non-standard one
Posted: Wed Dec 28, 2011 1:50 pm |
Aftermarket one then
| Citroen DS3
D-style +
1.6 VTI | |
Posted: Wed Dec 28, 2011 1:51 pm |
gold star
Posted: Wed Dec 28, 2011 1:55 pm |
Can't see why not, just drop the gear linkages for more room
Posted: Wed Dec 28, 2011 1:58 pm |
and maybe the subframe??
| Renault Clio III RS - Race Car
Former Poverty 206 XS 1.6Turbo Owner  | |
Posted: Wed Dec 28, 2011 3:36 pm |
Subframe and steering rack too.
Posted: Thu Dec 29, 2011 11:31 am |
How much would it cost to get this done though as my skills with a spanner dont stretch that far.
Posted: Thu Dec 29, 2011 1:31 pm |
ring a few garages for some quotes, cant see it taking a fully qualified mechanic longer than 2 or 3 hours labour time?
Posted: Thu Dec 29, 2011 3:52 pm |
got mine done for 150 took about 3 hrs
i got mine dropped off its mounts 2 inch
Posted: Thu Dec 29, 2011 3:56 pm |
I had to lower the engine gearbox side, remove all thermostat housing pipes and well generally anything in the way
Big amounts of effort required
| Team Impossible Possible
Posted: Fri Feb 03, 2012 4:31 pm |
worth the effort tho i might add
